Anyone rebuilt their horns? #930328
02/16/11 01:12 PM
02/16/11 01:12 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
I have a nice looking set of 70-71 e-body horns in my T/A. The problem is they don't work. I saw a post on rebuilding these and captured the details. Has anyone done this with success? I have a few non-70/71 donor horns i can use for parts.
1970 Dodge Challenger T/A
Re: Anyone rebuilt their horns? [Re: jeff968] #930329
02/19/11 02:08 AM
02/19/11 02:08 AM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
If you don't get an answer to your question, try this. Spray some WD-40 or something similar inside the horn for a few days and the horn with a soft rubber mallet. This will usually free them up.
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: Anyone rebuilt their horns? [Re: jeff968] #930330
02/19/11 09:23 AM
02/19/11 09:23 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I missed that thread. Do you have a link to it?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Anyone rebuilt their horns? [Re: jeff968] #930331
02/19/11 12:51 PM
02/19/11 12:51 PM
Chicagoland
cudastruction Offline
Chicagoland
I copied this from the forum a while ago but I have not had a chance to do it yet...
"Here's my step-by step "how to", not all the tough really.
1. Split the horn in half.
From the power side, take a drill bit that is larger then the swedge and drill until it is no longer holding the two halfs together. Drill all 6 and pull it apart. Make note of the orientation of the metal diaphragm and the back halve to the trumpet. While you have the drill out, take a number #29 drill bit and drill out the trumpet side and tap it for a #8-32 machine screw.
2. Look at the inside of the magnet and you’ll see two small contacts, that’s where all the problem is. Take a piece of sand paper folded in half, open the two contacts with a screw driver then slide the paper between them and take the screw driver out. Pull the sand paper, this will clean both contacts as you do that.
3. If the cardboard gasket that is on the trumpet is bad, cut a new on from any paper stock the thickness of, lets say, the cover of your Mopar Muscle magazine.
4. Your ready to test.
Reassemble the horn, I use 3 vise grips and make sure they’re tight.
5. Screw the horn assembly together and use a cutoff wheel to trim the threads flush then use the side of the wheel to grind off to a flat the other end of the screw.
I've done a half dozen horns so far and they all work."
Again, not my information but nice to have (thanks to whomever originally posted this).
Al
Re: Anyone rebuilt their horns? [Re: jeff968] #930332
02/22/11 02:09 PM
02/22/11 02:09 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
