Heres some pics of the Dakota Project
#929817
02/15/11 08:47 PM
02/15/11 08:47 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
The cage you hardly can tell is there. This will change a little once the door bars are installed. I wait til the last minute to do these as they are easy but get in the way while building.
Leon
Re: Heres some pics of the Dakota Project
[Re: MR_P_BODY]
#929819
02/15/11 09:53 PM
02/15/11 09:53 PM
Leon441
Lynchburg, VA
Here is the dash bar. I notched the steering column mount. The bar is welded to the body on both ends and into the steering column mount. Try tearing this one out.
[Re: Leon441]
#929820
02/15/11 09:59 PM
02/15/11 09:59 PM
Leon441
Lynchburg, VA
Here is the A-pilar/halo and main hoop. There is no way to ever change a headliner now. The tallest of drivers like me fit.
[Re: Leon441]
#929821
02/15/11 10:04 PM
02/15/11 10:04 PM
Leon441
Lynchburg, VA
Here is my favorite view from the drivers seat. Full view through every window. No intrusions.
[Re: Leon441]
#929822
02/15/11 10:08 PM
02/15/11 10:08 PM
Leon441
Lynchburg, VA
Here is the second stage of the project. Removed the factory spring hangers. Then made a front spring hanger assembly to weld into the frame. Here is a pic of the hanger with support plate bridging the frame rail.
[Re: one bad fish]
#929824
02/15/11 10:12 PM
02/15/11 10:12 PM
Leon441
Lynchburg, VA
Is is the same spring hanger PS viewed from outside of framerail. The truck has split mono's and cal tracks.
[Re: Leon441]
#929825
02/15/11 10:16 PM
02/15/11 10:16 PM
Leon441
Lynchburg, VA
Really struggled with what I wanted to do here. Could have simply cut out and replaced with tubing. But, said anybody can do that. The spare tire mount, the way it is made really puts some regity in the frame. So I lightened it. LOL
[Re: Leon441]
#929826
02/15/11 10:20 PM
02/15/11 10:20 PM
Leon441
Lynchburg, VA
This is a store bought peice from AFCO. It replaced the swing style hanger. Main reason for using this was to raise the leaf up 2" to match the front.
[Re: Leon441]
#929827
02/15/11 10:21 PM
02/15/11 10:21 PM
Posts: 3,396 Pa
Hot 340
Pa
[Re: Leon441]
#929828
02/15/11 10:22 PM
02/15/11 10:22 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
are you building this for any particular class? nice work
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Leon441]
#929829
02/15/11 10:26 PM
02/15/11 10:26 PM
Leon441
Lynchburg, VA
Here is a pic of the Dana 60 housing. It will be filled with Strange 35 spline axles with 5/8 studs and a spool.
Yes, this is a set of Santhuff double adjustable shocks the owner stole. They are just hanging on some bolts right now awaiting the lower mounts being cut at a lazer shop. I plan to weld the mount to the caltrac lower spring plate. Then if for some reason we upgrade the suspension or want to build another car this is the last set of rear shocks he should ever need to buy. OVERKILL absolutely. But, isn't that what racing is all about.
[Re: Leon441]
#929830
02/15/11 10:26 PM
02/15/11 10:26 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Looking good...Keep the pics coming...Want to build another cage....LOL I modded my spare tire carrier too. Here's my shock set up before I installed the Monoleafs and Caltracs. http://www.nmbuilder.com/Shocks_5a.jpg
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Leon441]
#929833
02/15/11 10:34 PM
02/15/11 10:34 PM
Posts: 3,396 Pa
Hot 340
Pa
NOT MY TRUCK
OK!
[Re: Dartin]
#929837
02/15/11 10:46 PM
02/15/11 10:46 PM
Posts: 6,150 Melbourne , Australia
LA360
I thought the travel of the AFCO sliders were to follow the centerline of the leaf springs hole centres? That's how I installed the last set I ran, and will be doing the same with the ones I have now. Nice looking Dakota though!
Alan Jones
[Re: LA360]
#929838
02/15/11 10:59 PM
02/15/11 10:59 PM
Leon441
Lynchburg, VA
Sorry there is no pic showing both the front hanger and rear slider in the same pic.
[Re: Leon441]
#929839
02/17/11 06:53 PM
02/17/11 06:53 PM
Leon441
Lynchburg, VA
Shouod have some new pics soon. More parts are in.
Leon
[Re: Leon441]
#929846
02/27/11 09:17 PM
02/27/11 09:17 PM
Leon441
Lynchburg, VA
Here is one with the new Holeshot wheels and MT 28X10.5 tires.
Leon
[Re: Leon441]
#929848
02/27/11 09:21 PM
02/27/11 09:21 PM
Leon441
Lynchburg, VA
Passenger side with a little better view of front hanger, cal trac bars
[Re: Leon441]
#929850
02/27/11 09:22 PM
02/27/11 09:22 PM
Leon441
Lynchburg, VA
Here is one of the shock mounting. Had lazer cut plates fixed up. Then welded to the Cal Trac U-bolt mounting. Made the top mount too.
Leon
[Re: Leon441]
#929852
03/01/11 10:33 PM
03/01/11 10:33 PM
Adobedude
New Mexico
More pics... Especially of the shock mounting...
[Re: Adobedude]
#929853
03/09/11 10:40 PM
03/09/11 10:40 PM
Leon441
Lynchburg, VA
Top shock mount. Threaded chrome moly tube with a 3/8" .080 wall tube for support. Want to guess where the small tubing came from.LOL
[Re: Leon441]
#929854
03/09/11 10:42 PM
03/09/11 10:42 PM
Leon441
Lynchburg, VA
here is another angle of the bottom. Cal track plate did not provide the mount we wanted. They had some with mounts but not what we needed.
[Re: Leon441]
#929855
03/09/11 10:44 PM
03/09/11 10:44 PM
Leon441
Lynchburg, VA
Here is a pic that shows an Ultimate cover made for JEGS. Milled out the JEGS logo. The allen support bolt split so another on is on the way.
The brakes are AEROSPACE.
[Re: Leon441]
#929856
07/27/11 01:01 AM
07/27/11 01:01 AM
Posts: 791 Bama
Randy..
Bama
[Re: fishy340]
#929858
08/15/11 01:16 AM
08/15/11 01:16 AM
Posts: 791 Bama
Randy..
Bama
