66 coronet steering column rebuild #929813
02/15/11 08:16 PM
02/15/11 08:16 PM
Memphis, MO
X
xpsyclonex2002 Offline OP
X
Memphis, MO
Swapping from column shift to floor shift. Have located floor shift column. I need to paint it and want to blast it first. i'm gonna go ahead and replace the turn signal cam and upper bearing. I have the column out of the car and the steering wheel off. I have the cam disconnected and the snap ring off. How do I get the shaft off the bearing and the collar off the long tube? I found a sweet link to pictures but not enough info.
http://s218.photobucket.com/albums/cc255...nt=IM006199.jpg
Re: 66 coronet steering column rebuild [Re: xpsyclonex2002] #929814
02/16/11 12:31 PM
02/16/11 12:31 PM
Memphis, MO
X
X
Memphis, MO
bump
