Bigblock timing order--stupid ???s inside #92968
07/22/08 03:30 PM
07/22/08 03:30 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
OK, just to make sure I don't goof this up, the bigblocks firing order around the distributor is counter clockwise correct?
And number one should be facing towards the front of the engine? My distributor doesn't have a vacuum canister, so I can turn the distributor without it touching the head.
Sorry. This is my first RB, and I couldn't find the info I need in the tech pages, or my FSM for that matter.
codfish
Re: Bigblock timing order--stupid ???s inside [Re: codfish] #92969
07/22/08 03:40 PM
07/22/08 03:40 PM
Put the oil pump drive shaft in with the slot in line with the crank . Standing at the pass side looking at the dist the #1 is usually about 4 - 5 o- clock then you are correct go counter clock wise 1 8 4 3 6 5 7 2
Re: Bigblock timing order--stupid ???s inside [Re: ] #92970
07/22/08 04:47 PM
07/22/08 04:47 PM
hops440 Offline
hops440  Offline
Try this...
Re: Bigblock timing order--stupid ???s inside [Re: hops440] #92971
07/22/08 09:57 PM
07/22/08 09:57 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
unless you want it exactly like the factory did # 1 can really be anywhere you want , especially if you are custom making your wires , then just follow the firing order from there .
YMMV
Re: Bigblock timing order--stupid ???s inside [Re: JohnRR] #92972
07/22/08 10:54 PM
07/22/08 10:54 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Thanks guys.
I did it right for once
codfish
