330 desoto hemi to dakota AX15 transmission #929674
02/15/11 05:36 PM
02/15/11 05:36 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
a buddy of mine wants to do this combo,the hemi IS NOT the extended bell type, i have a 8 bolt hemi flywheel that is about 14 3/4 in diameter 146 tooth,the dakota used a 13 3/4 diameter flywheel,143 tooth
can the 14 3/4 be turned down to 13 3/4 ,use the 143 tooth ring gear and will the dakota AX15 bolt to the back of the Hemi and will the dakota starter line up with the flywheel to start the engine??
Re: 330 desoto hemi to dakota AX15 transmission [Re: rhad] #929675
02/15/11 09:38 PM
02/15/11 09:38 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Try here they have alot of info and the adaptors for the swap.Wish they were around when I did mine
http://www.hothemiheads.com/transmission_adapters/adapter_torqueflite.html
NS1AAR
Re: 330 desoto hemi to dakota AX15 transmission [Re: ns1aar] #929676
02/15/11 10:13 PM
02/15/11 10:13 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Just let your friend know that very little is available to Hot Rod a Desoto Hemi (I own a 1957 341). Cool engines but EXPENSIVE to buy aftermarket parts for (if you can find them). If he's good at making one off custom parts he'll be in allot better shape.
Here are the Desoto Hemis that were produced. Only Desoto Hemi parts interchange, Desoto, Dodge and Chysler Hemi parts are all unique. For ease of identification, factory 2 barrel engines were "Firedome" engines, same engine with a 4 barrel intake was a "Fireflite", same engine with a dual 4 barrel intake (and a few extra cubes) was the "Adventurer"
DeSoto FireDome 276 ci 160 hp 250 ft-lb
1953 DeSoto FireDome 276 ci 160 hp 250 ft-lb
1954 DeSoto FireDome 276 ci 160 hp 250 ft-lb
1955 DeSoto FireDome 291 ci 185 hp 245 ft-lb
1955 DeSoto FireFlite 291 ci 200 hp 274 ft-lb
1956 DeSoto FireDome 330 ci 230 hp 305 ft-lb
1956 DeSoto FireFlite 330 ci 255 hp 350 ft-lb
1956 DeSoto Adventurer 341 ci 320 hp 356 ft-lb
1957 DeSoto FireDome 341 ci 270 hp 350 ft-lb
1957 DeSoto FireFlite 341 ci 295 hp 375 ft-lb
1957 DeSoto Adventurer 345 ci 345 hp 355 ft-lb
Re: 330 desoto hemi to dakota AX15 transmission [Re: ScottSmith_Harms] #929677
02/15/11 11:13 PM
02/15/11 11:13 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
TR waters is a member on here to,has bellhousing adapters for early Hemis.
http://home.together.net/~twaters/
RT
