Page 1 of 5 1 2 3 4 5
fixin' up old heads #929156
02/14/11 11:35 PM
02/14/11 11:35 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
with so many new head offerings available these days, it often doesnt make much sense to try and bring a well used set of old OE heads back to life.
unless its a resto type application, or a stock appearing racing class.
i recently went through a set of old, well used J heads for a customers 71 340 car.
for his purposes, he elected to not go with an alternative replacement head, but instead wanted to keep the "correct" heads on the car.
these were some "well used" heads, and were still being run on the motor right up until he sent them to me to refurbish.
they had been "done" at least twice before i got them.
anyway.....heres some pics:
after being oven cleaned.....exhaust valve seat recession......they were all about this way
Re: fixin' up old heads [Re: fast68plymouth] #929157
02/14/11 11:37 PM
02/14/11 11:37 PM
So. Burlington, Vt.
So. Burlington, Vt.
a couple of the intake ports must have sat with some water in them at some point in their life.
they didnt look this bad when they were still oily from being on the motor.
Re: fixin' up old heads [Re: fast68plymouth] #929158
02/14/11 11:39 PM
02/14/11 11:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
goona need to install a few seats to brings these back to life.
Re: fixin' up old heads [Re: fast68plymouth] #929159
02/14/11 11:41 PM
02/14/11 11:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
exhaust valves werent quite sealing 100%
Re: fixin' up old heads [Re: fast68plymouth] #929160
02/14/11 11:43 PM
02/14/11 11:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
multi-groove locks are designed to allow the valve to float within the locks, and act as a rotator.
however.....that set-up doesnt last indefinately.
old valve with worn grooves vs new valve.
these heads with be getting stainless valves with single grooves.
Re: fixin' up old heads [Re: fast68plymouth] #929161
02/14/11 11:46 PM
02/14/11 11:46 PM
So. Burlington, Vt.
So. Burlington, Vt.
these heads had a variety of different guide repairs......not that uncommon to find on old stuff thats been worked on before.
Re: fixin' up old heads [Re: fast68plymouth] #929162
02/14/11 11:49 PM
02/14/11 11:49 PM
So. Burlington, Vt.
So. Burlington, Vt.
okay....at this point ive got a set of well used 2.02 J heads that hae been oven cleaned and magnafluxed.
no cracks.....so lets begin.....
install new guides, and machine for new style Viton seals.
sorry....pictures kinda blurry.
Re: fixin' up old heads [Re: fast68plymouth] #929163
02/14/11 11:52 PM
02/14/11 11:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
install seat inserts and machine "valve job" into new seats, and use a bowl cutter to blend the insert into the bowl.
Re: fixin' up old heads [Re: fast68plymouth] #929164
02/14/11 11:53 PM
02/14/11 11:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
a little bowl porting to bring the flow up a bit......
Re: fixin' up old heads [Re: fast68plymouth] #929165
02/14/11 11:56 PM
02/14/11 11:56 PM
So. Burlington, Vt.
So. Burlington, Vt.
heres that intake port that was really rusty.
a new seat, some blending.........not too nasty now.
Re: fixin' up old heads [Re: fast68plymouth] #929166
02/14/11 11:57 PM
02/14/11 11:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
stainless 2.02/1.60 valves with back cut
Re: fixin' up old heads [Re: fast68plymouth] #929167
02/14/11 11:58 PM
02/14/11 11:58 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
good looking work fast68plymouth
Re: fixin' up old heads [Re: fast68plymouth] #929168
02/14/11 11:59 PM
02/14/11 11:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
new springs/retainers/10deg locks/Viton seals
Re: fixin' up old heads [Re: fast68plymouth] #929169
02/15/11 12:01 AM
02/15/11 12:01 AM
So. Burlington, Vt.
So. Burlington, Vt.
oh yeah.....a little blending of the pushrod pinch.....i mean, hey.....i had the grinder all fired up anyway
Re: fixin' up old heads [Re: fast68plymouth] #929170
02/15/11 12:04 AM
02/15/11 12:04 AM
So. Burlington, Vt.
So. Burlington, Vt.
mill the deck surfaces, clean the heads and all the parts, and assemble.
Re: fixin' up old heads [Re: fast68plymouth] #929171
02/15/11 12:06 AM
02/15/11 12:06 AM
So. Burlington, Vt.
So. Burlington, Vt.
cleaned head, ready for assembly
Re: fixin' up old heads [Re: fast68plymouth] #929172
02/15/11 12:08 AM
02/15/11 12:08 AM
So. Burlington, Vt.
So. Burlington, Vt.
finished head.
not a cheap way to go about it......but sometimes its still the right choice.
flow #'s as pictured:
28" test pressure, 4.00" bore, .750" thick radius plate
lift----I/E
.100--65.8/53.6
.200-131.8/102.9
.300-192.8/136.4
.400-226.3/152.5
.450-226.3/156.2
.500-226.3/158.0
.550-222.5/160.0
.600-221.4/160.5
a stock 2.02 J head thats not used up like these were usually flows a touch over 200cfm on the intake, and 145-150 on the exhaust.
i tested one of the exhaust ports with the stock valve and the pounded seat and it was around 135cfm.
Re: fixin' up old heads [Re: fast68plymouth] #929173
02/15/11 12:13 AM
02/15/11 12:13 AM
Renton Washington
Triple Threat Offline
Renton Washington
Thank you for posting this!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: fixin' up old heads [Re: Triple Threat] #929174
02/15/11 12:29 AM
02/15/11 12:29 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
no kidding ive done my fair share of those heads..
..i am flabergasted at the keeper wear on the valves...
was he running alot of valve spring?..also curious as to valve stem wear on the valve...? was there much?
i hope he is getting new rings in the motor..cause its all gonna go out that end now..
if not...lol....
nice job..Dwayne.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: fixin' up old heads [Re: cheapstreetdustr] #929175
02/15/11 12:55 AM
02/15/11 12:55 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Im also one that likes new replacement stuff that why this post is awesome. MAN those heads were thrashed! goes to show what can be pulled back! Great stuff good series to show all steps.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
