Re: Do I run a fuel return???
[Re: wmwalden]
#928777
02/14/11 04:40 PM
02/14/11 04:40 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
here is how mine is. use a mallory 4309 regulator but put it after the carbs so cool fuel constantly runs past the carbs. this is how mine is set up and it works great. you just need to figure out how you want to do it if your trying to hide it
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: wmwalden]
#928779
02/15/11 12:42 PM
02/15/11 12:42 PM
sixpackgut
Charleston
years ago before i put in place the current fuel system that i run now, i tried using that stock filter setup, it didnt really work to good and guys on here told me the same thing. someone also commented that the vapor seperator filter in the pick looks the same but doesnt work the same as the originals so i scrapped it.
the way mine works will keep the fuel cool within inches of the carbs and has worked well
[Re: wmwalden]
#928784
02/18/11 11:41 PM
02/18/11 11:41 PM
fast68plymouth
So. Burlington, Vt.
personally, i wouldnt run the return.
if you wanted it there for looks, i would have it plugged off inside so no fuel would return to the tank.
[Re: Cab_Burge]
#928787
02/19/11 11:41 AM
02/19/11 11:41 AM
Challenger 1
Cincinnati, Ohio
2x2
Me too, something else to go wrong
Just curious, what could go wrong? If there were doubts, one could put a small clamp across the rubber hose between the return nipple and the steel return line blocking it off to test.
Some hot day on the street it will be so worth it, imo.
[Re: wmwalden]
#928788
02/19/11 12:02 PM
02/19/11 12:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm a firm believer in return systems... if needed you can put a orifice in the return rubber hose to regulate the amount of return fuel... just drill a small hole in a piece of brass round stock and slip it in the hose... but if the vapor can has a orifice in it you should be fine(depending on the flow of your ele pump)
