Re: Lean Burn Conversion Question
[Re: mantonas]
#928694
02/16/11 09:28 PM
02/16/11 09:28 PM
Posts: 4,215 Canada -- Posts: 4034 -Registe...
5thAve
I took another look under the hood yesterday, and I don't know what I was thinking, there is a ballast resistor installed but there's no ECU in the car. I'll just have to wire one in to make the conversion.
Those older computers used a seperate ballast resistor. Bonus for you because that means part of the wiring is already done. You just need to finish the other half of it.
