Rod Bearings for a 408 stroker
#928426
02/14/11 12:39 AM
02/14/11 12:39 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I need a set of rod bearings for my 408 stroker. The kit I bought in 2001 came with Clevite 77's. I just opened the packages and 4 of the 8 are defective. They are brown, look burnt, with blueing around the edges.
Im afraid to use them and need to order another set. The ones I have are CB-481-H Summit lists 2 a CB481HN and CB481HXN, Can anyone tell me what the difference is? Any recommendations are appreciated. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Rod Bearings for a 408 stroker
[Re: RapidRobert]
#928428
02/14/11 01:02 AM
02/14/11 01:02 AM
finadk
East Brunswick, NJ
I dont think so, they came from a reputable shop, and there is no sign of wear, its hard to see in the pics but it looks like they were overheated during manufacturing. Some of the brown comes off with carb cleaner, its not oil, more like a varnish. Very strange.
Scott
1976 Corvette
[Re: dodgeboy11]
#928430
02/14/11 02:06 AM
02/14/11 02:06 AM
finadk
East Brunswick, NJ
Thanks, if it was just the residue I might try it. There are some with the blueing just right at the bearing edge. Its not worth the risk. Thanks for the info on the part numbers, and the tip on checking them all first with the bearings that I have, at least if some need adjustment I can order what I need. Scott
Scott
1976 Corvette
[Re: finadk]
#928431
02/14/11 02:09 AM
02/14/11 02:09 AM
finadk
East Brunswick, NJ
Dodgeboy What is the difference in the part numbers CB481H that I have and CB481HN that I can order now? 4 of the 8 look good so I really just need to buy four if they are still the same.
Scott
1976 Corvette
[Re: finadk]
#928432
02/14/11 02:13 AM
02/14/11 02:13 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
H bearings have a chamfer, they have been phased out & replaced with a narrower bearing designated HN
Be very careful when installing them to be sure the shells mate properly with the narrowed side to the radiused area of the crankshaft...
[Re: 1_WILD_RT]
#928433
02/14/11 10:56 AM
02/14/11 10:56 AM
finadk
East Brunswick, NJ
Are all currently available bearings the narrow design? I guess I should replace the entire set and not mix the 4 good camfered ones with the new narrow ones. Scott
Scott
1976 Corvette
[Re: finadk]
#928434
02/14/11 02:11 PM
02/14/11 02:11 PM
finadk
East Brunswick, NJ
I spoke to the place I bought the kit from and my local machine shop, apparantly this discoloration is normal for a high performance bearing and there is nothing wrong with them.
Scott
Scott
1976 Corvette
[Re: finadk]
#928435
02/14/11 09:23 PM
02/14/11 09:23 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Nothing wrong with them. that's how they come. However, if you have a cast crank, you might want the HN bearings. Otherwise you may find you have no rod side clearance.
