Re: Indy 440 EZ Heads
[Re: Kudakidd]
#927870
02/13/11 03:03 PM
02/13/11 03:03 PM
Posts: 43,754 Bend,OR USA
Cab_Burge
Anyone using them? Pros/ cons? They'd be going on my 440 in the Duster (9.00:1 comp., .509" cam, Demon 750, Eddy Performer RPM, Headers,3.55 Sure grip, 4-speed)
which material heads, aluminum or cast iron? If aluminum I would cut them to help incresase the compression ratio, if there the 440-1C I would leave the compression where it is To answer your question on use, I have a CNC ported set as wel as several other sets of iron and aluminum and the 440-1 CNC set has made the most power on any of my N/A engines so far IHTHs
chico
[Re: Cab_Burge]
#927871
02/13/11 03:26 PM
02/13/11 03:26 PM
Posts: 7,910 Witness Protection Program
Kudakidd
Thanks Cab. I'm interested in the aluminum versions. I know it's not the smartest move, but I'm also hoping to run them right out of the box.
[Re: Kudakidd]
#927875
02/13/11 07:05 PM
02/13/11 07:05 PM
Posts: 31,203 Oregon
AndyF
Edelbrock heads would be a better match for the rest of your parts.
[Re: fourgearsavoy]
#927877
02/13/11 09:35 PM
02/13/11 09:35 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I also bought my EZ's through Nick at Compu-flow, already set up for a solid roller by him. I just bolted them on after he did his magic. I hope they run as good as they look.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#927878
02/13/11 11:01 PM
02/13/11 11:01 PM
Posts: 10,613 Rittman Ohio
fourgearsavoy
Rittman Ohio
You won't be disappointed at all My little engine is an overachiever and I have no doubt it's in the heads. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: tboomer]
#927882
02/14/11 01:38 AM
02/14/11 01:38 AM
Posts: 126 Nevada
theman440
Nevada
I run E-Z's om my .030 over 440 and am very pleased with them. I would suggest upgrading to better spring retainers - I broke one at 6500 rpm, luckily no major damage. Mine even use the standard port window. I had mine milled to get 72cc chambers for 11 to 1 CR. I run a .600 lift flat tappet solid cam, 1050 dominator, edel. victor, race weight is 3650 - best of 10.58@125 at 2100 ft.
[Re: theman440]
#927883
02/14/11 03:41 AM
02/14/11 03:41 AM
Posts: 577 Arkansas
Adrielp
Arkansas
I will let you know in 3 weeks or so. We just installed a set on our bracket car and the engine is going back in Friday if we get our parts. We may visit the engine dyno later next week as well, I will keep you posted on numbers whether we hit the track or the dyno. We were running 6.50's in the 1/8th with our iron headed engine so we should definitely improve that with the upgrades we've made.
Adriel Paradise Substation Design Engineer III
[Re: AndyF]
#927884
02/14/11 11:24 AM
02/14/11 11:24 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
, Mark you really should dump the big dollar purchase into the poorly executed shortblock that came in that car. I talked to Dan about your goal after the last time we talked and he said all you need is a cam change on your current setup to get you there.
I'd change the cam and get a little port work done to the 915's ...
[Re: JohnRR]
#927885
02/14/11 01:11 PM
02/14/11 01:11 PM
Posts: 3,210 robin hood country
deaks
robin hood country
If it were me, i would buy a set of ported rpm's, mill .060 off them to get the compression up and keep the motor under 6500. Sport 440's car goes mid 10's with your set up and Eric used to as well. Just my Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Kudakidd]
#927887
02/14/11 10:20 PM
02/14/11 10:20 PM
Posts: 14,540 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
i agree with the others that said the RPM heads would be a better choice for the current combo. i dont necessarily feel they would offer better performance than the EZ, but should be equal on that combo, at a lesser cost. however, if future upgrades are part of your plans, especially in terms of displacement, then it makes more sense to just get the better heads now.
OOTB std port EZ's flow around 295cfm, a nice valve job with back cut valves and the bowls blended and chambers ported around 315. open to MW size and your in the 340cfm range.
[Re: JohnRR]
#927888
02/15/11 11:52 AM
02/15/11 11:52 AM
Kudakidd
Thanks John and everyone else. John knows the car personally, and maybe the 'magic bullet' is not a head change, but a cam change. But what? I was hoping the EZ's with the small chambers and better flow would be the ticket.
