Re: Comp Roller Lifters - EDM axle oiling
[Re: Bob_Coomer]
#927609
02/14/11 10:07 PM
02/14/11 10:07 PM
Posts: 16,930 NC
440Jim
NC
Here is a common lifter sold by PBM, made by Morel these are very good lifters for the money. ... I took a bunch of measurements on these also and posted them several months back. The wont clear the taller lifter boss's in the aftermarket block's however.
Interesting. I run a stock block, so that isn't an issue. The axle dia, wheel dia, etc. would be good info that is not normally available in the catalog. And the pushrod seat height is important to see if a different set of pushrods ($$$) is needed.
[Re: Bob_Coomer]
#927610
02/14/11 10:25 PM
02/14/11 10:25 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Here is a common lifter sold by PBM, made by Morel these are very good lifters for the money. Seems to be the same lifter offered by Lunati, Herbert and other company's etc. I took a bunch of measurements on these also and posted them several months back. The wont clear the taller lifter boss's in the aftermarket block's however. I can get these for well under $300 a set, and they have been proven reliable.
Bob, are those lifter bars hitting the block? Solve the problem a bigger cam if they are.
[Re: 440Jim]
#927611
02/16/11 06:02 PM
02/16/11 06:02 PM
Posts: 16,930 NC
440Jim
NC
The recent topic on roller lifters had me looking at the Comp Cams web site. Their old favorite BB Mopar roller lifter is 829-16. These have a solid lifter body (according to the picture), but the description says: Quote:
EDM Oil Injection™ Technology guarantees that the bearing assembly receives constant, pressurized oil flow via precision hole aimed at the bearings
Comp 829 roller lifter web page
Is this a misprint? Did they just put the same description (right or wrong) for all their roller lifters? Have they added an oil hole to the side of the lifter?
I just got a response from Comp Cams:
Jim,
Yes sir that IS a misprint, the Chrysler roller lifters do NOT have the EDM hole. With the lifter not having an oil band, there would be nowhere to get the oil from. Sorry for the confusion. If you need anything else please let us know. We are working on fixing a few small misprints in the catalogue. There is A LOT of information to process lol.
Thanks, Chris Ryan
COMP performance group Technical Department 3406 Democrat Rd. Memphis,TN 38118 Fax: (901)366-1807 cryan@compcams.com
[Re: 440Jim]
#927612
02/16/11 06:28 PM
02/16/11 06:28 PM
Posts: 976 ontario canada
mac56
ontario canada
Jim,
Thanks, Chris Ryan
Thanks for clearing that up Jim. Just to be clear on another thing do the 87019-16 you mentioned have the same body as 829-16 only with offset pushrod? Mark
[Re: mac56]
#927613
02/16/11 07:05 PM
02/16/11 07:05 PM
Posts: 8,907 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
They're hitting on the base circle. A larger Base circle usually means less lift since the lobe can only be as big as the bearing.
[Re: mac56]
#927616
02/16/11 09:22 PM
02/16/11 09:22 PM
Posts: 16,930 NC
440Jim
NC
I never mentioned them in this post and I have no idea.
If you are considering them, let us know too.
[Re: 440Jim]
#927618
02/25/11 08:48 PM
02/25/11 08:48 PM
mac56
ontario canada
Called comp and was told these are the same as 829s only with offset pushrod cup.
