Page 1 of 3 1 2 3
Help picking a cam #927459
02/13/11 01:05 AM
02/13/11 01:05 AM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
Need some help picking a cam for a low budget build.
.040 over 440, Keith Black pistons, 6 pack rods. 10 to 1 compression. Street Dominator Intake, 800 Holley Double Pumper, 346 heads that are stock except being freshened. 2 inch headers. Car should weigh around 3800 lbs. I have a 9.5 inch converter that should flash close to 4 thousand RPMs. 3.55 or 4.10 gear.
Im figuring the headers are probably a little big, but that is all I have at the moment.
Due to a shortage of funds, Im stuck with an off the shelf grind. Looking for recommendations for both a solid and a hydraulic.
If anybody has built a similar motor, ET, MPH and cam used would be great also!!!
BTW, Im not interested in the VooDoo grinds, anything else is fine. Long story.
Re: Help picking a cam [Re: Verga] #927460
02/13/11 01:18 AM
02/13/11 01:18 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
525 comp XE grind loks pretty good for your combo. , that being said i went with the 564 lift xe grind for the 440 in my A100.
Re: Help picking a cam [Re: Randy..] #927461
02/13/11 02:24 AM
02/13/11 02:24 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I went with an old skool MP528 mechanical. WOW what a great cam. Daily driveable, medium lope, fries the 295/60-15 BFG drag radials thru 3.55 gears. 470". See info in my profile.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Help picking a cam [Re: Verga] #927462
02/13/11 04:01 AM
02/13/11 04:01 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run a voodoo cam, no problems. I would have suggested a voodoo 60304 would fit the bill nicely.
Re: Help picking a cam [Re: DaytonaTurbo] #927463
02/13/11 04:07 AM
02/13/11 04:07 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Comp XS 282S
Re: Help picking a cam [Re: Verga] #927464
02/13/11 02:38 PM
02/13/11 02:38 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Since you said budget build, i'm guessing you may be using the stock rockers. If so, i've had good luck with the old Comp 292 Magnum hyd. .030 440 8.5 comp, 906s pocket ported when i was 20yo and didn't know what i was doing(still don't), Torker,750dp, 10 in GER stalled about 3800, 3.23s, 28 x9 slicks, 68 Satellite street car all steel except for 6 pak hood. 12.35 at 106, 1.69 60 ft. Cam has been in for about 25 years and hasn't gone flat yet in spite of me not always changing the oil as often as i should. Car sometimes sits for months and then might be driven almost every day for a while.
Re: Help picking a cam [Re: redmist] #927465
02/13/11 02:40 PM
02/13/11 02:40 PM
Central NC
gch Offline
gch  Offline
Central NC
Guy here selling an engle 230-238 @ .050 would be A GREAT CAM for you.
Headers are too big but 4.10's will help the loss of bottom end/midrange(especially on part throttle)if you care.
Re: Help picking a cam [Re: forphorty] #927466
02/13/11 03:23 PM
02/13/11 03:23 PM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
Ive actually got some 1.6 rockers.
What RPM do you shift that cam?
Re: Help picking a cam [Re: Verga] #927467
02/13/11 05:00 PM
02/13/11 05:00 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: Help picking a cam [Re: forphorty] #927468
02/13/11 05:11 PM
02/13/11 05:11 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Narrow down to solid or hydraulic first?
Re: Help picking a cam [Re: RemCharger] #927469
02/13/11 09:31 PM
02/13/11 09:31 PM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
Lets say a solid.
Looks like the Comp 292 should work if I go with a hyd.
"Im supercharged, might explode in your face"
Re: Help picking a cam [Re: Verga] #927470
02/13/11 10:21 PM
02/13/11 10:21 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Lets say a solid.
There are way better cams now then the old cc292. A buddy of mine built a very similar deal last year, had an old comp 280 (230@50) and went to the comp 284xe and gained around a half second. This was in a fully stock body '68 Bee, ended up going 11.6X .
I have had good luck with the.528 mp solid too, but there are better grinds now worth investigating.
Re: Help picking a cam [Re: RemCharger] #927471
02/13/11 11:13 PM
02/13/11 11:13 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Not sure on "way better" part......I laugh everytime a new grind is the shiznit, and the old stuff is junk. My junk runs decent (11.30s)with pretty old lobes (Comp TL lobes).....Thinkin about having Dwayne grind me a cam with the super duper new stuff for a comparison.
Well lets see... the XE284 grind has 10 more degrees on the intake side than the 280, 16 more on the exhaust..., not to mention the extra .25 ish more of lift. The XE grind has 13 more degrees at .200 than the 280. So yeah, it should be quicker. I dont think that is a good comparison.
The XE274 would be a better comparison. 3 degrees more at .200 than the 280. Same intake duration at .050.
The XE284 and 292Mag would be a much better comparison, for the larger grinds. I'll throw it out that in a heavy car the 292 takes the XE284......
Im not a fan of split duration cams, and after talking at length with Dwayne, I understand why.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Help picking a cam [Re: Von] #927472
02/13/11 11:23 PM
02/13/11 11:23 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
All I was trying to get at is don't buy a sh!++% old cam. I subscribe to the theory that there is no such thing as too big of a cam/conv/gear. Of course this is the wrong forum for that, but I must explain where I come from.
Re: Help picking a cam [Re: RemCharger] #927473
02/13/11 11:26 PM
02/13/11 11:26 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I agree on the cam/conv/gear thing, but not that the 292 is a sh$$$ old cam. Ive known forphorty for a long time and his stuff runs hard...with hardly anything. Ask the all knowers if his stuff should run 12.30s with... gasp....3.23s...
Re: Help picking a cam [Re: Von] #927474
02/13/11 11:40 PM
02/13/11 11:40 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Anything is possible. In this case, WEIGHT is the
big factor. Bunch of mass to move (a little over two tons w/ driver) and the low end/strong midrange level cams would get the job done. Higher lifts (.500 or better) would only help MORE.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Help picking a cam [Re: Von] #927475
02/13/11 11:42 PM
02/13/11 11:42 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The only reason I would disagree with that is there are better cams now. The lift on that is .501(?)...And with the bending and deflection of stuff, its under 500 lift.
Don't get me wrong, I've seen those cams work too.
Re: Help picking a cam [Re: RemCharger] #927476
02/13/11 11:56 PM
02/13/11 11:56 PM
Desert Tracker
Desert Tracker
A lot of guys optimize those MP cams to run better
times with the rest of the combo on the engine.
It's a hit or miss game, what could be the cam holding power back could actually be tuning problems, wrong intake, exhaust restrictions, too heavy car for combo, etc.
or visa-versa. EVERYTHING has to work together to produce good power!! And yes, not everybody wants to run an MP cam, there ARE many other choices.
Re: Help picking a cam [Re: HYPER8oSoNic] #927477
02/14/11 12:18 AM
02/14/11 12:18 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Who said anything about a MP cam??
Re: Help picking a cam [Re: RemCharger] #927478
02/14/11 12:21 AM
02/14/11 12:21 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Please define better....and why more lift is needed with stock castings?
Ive already discussed the same subject with Dwayne...
Page 1 of 3 1 2 3
