Page 2 of 3 1 2 3
Re: 6 Pack [Re: mikemee1331] #927146
02/13/11 04:12 PM
02/13/11 04:12 PM
mt
440_dup77 Offline OP
mt
Thats what it sounds like, will check. Thanks
Re: 6 Pack [Re: 440_dup77] #927147
02/13/11 04:53 PM
02/13/11 04:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
When it dies open the hood and check the center carb for fuel.
Re: 6 Pack [Re: 440_dup77] #927148
02/13/11 04:53 PM
02/13/11 04:53 PM
mt
mt
just one more thing,would it be the fuel pump.
Re: 6 Pack [Re: 440_dup77] #927149
02/13/11 05:09 PM
02/13/11 05:09 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If it acts like it's running out of fuel...Lot's of good suggestions here already.....Checking the float level is an easy start....Then after you've run the car check the center carb after it stalls and see if the carb is in fact out of fuel...Working the throttle after the stall to see if the accelerator pump is giving a shot is the first check to make sure it is in fact a fuel related issue....then you can work you're way from there....These checks cost you nothing but time....
Re: 6 Pack [Re: screamindriver] #927150
02/13/11 05:16 PM
02/13/11 05:16 PM
mt
mt
When it stops, thats what it does.Center carb gets gas.So it sounds like its stuck.
Re: 6 Pack [Re: 440_dup77] #927151
02/13/11 05:31 PM
02/13/11 05:31 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and yes, it could be your pump. it might not be able to supply enough volumn or the pressure has dropped. is this pretty much a stock setup?
Re: 6 Pack [Re: 440_dup77] #927152
02/13/11 05:40 PM
02/13/11 05:40 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What does this mean?
Re: 6 Pack [Re: BSB67] #927153
02/13/11 06:37 PM
02/13/11 06:37 PM
mt
mt
Forgot to take it out, had another statement to ad, but delete it.
Re: 6 Pack [Re: mikemee1331] #927154
02/13/11 06:45 PM
02/13/11 06:45 PM
mt
mt
Not stock.But this just started. Seam like when i started to adjust the carb,thats when things started to go haywire.It was running way to rich,but that is just a guess on my part.
Re: 6 Pack [Re: 440_dup77] #927155
02/13/11 07:06 PM
02/13/11 07:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i have to ask this question and please don't get offended........... do you have enough experience fiddling around with this? if you do i would suggest buying a carb rebuild kit and rebuilding the center carb. the kit itself is pretty cheap ($25) and it's not very hard. if you do decide to go this route i would suggest replacing the float (it doesn't come in the kit) at the same time.
Re: 6 Pack [Re: mikemee1331] #927156
02/13/11 08:59 PM
02/13/11 08:59 PM
mt
mt
Carbs,i dont fool with. All i know is to take them apart mike!
Re: 6 Pack [Re: mikemee1331] #927157
02/13/11 09:12 PM
02/13/11 09:12 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Unless you can afford to pay someone to work on your Six pack, you will need to acquire some carb tuning skills and basics. A six pack is nothing more than a 4 barrel with one extra set of rear barrels. It runs on the middle carb until engine demand / vacuum opens the end carbs. Either get a book and start reading or pay someone to work on it. There are plenty of books on how to rebuild and tune a Holley 2/4 barrel carb. Even if you send your carb off to be rebuilt it or even get new carbs that does not mean that will fix your problem. There are some adjustments and such that need to be made, like the idle mixture and the float levels, and the end carbs linkage. If they aren't right a brand new carb won't work correctly either. A Dodge or Plymouth factory service manual from 1970 will contain a good section on the care and adjustment of a factory 6 pack.
Re: 6 Pack [Re: Sixpak] #927158
02/13/11 09:21 PM
02/13/11 09:21 PM
mt
mt
Ok, got a guy coming over monday,To check the fuel pump,and carb,And if needs it,will put a kit in.Will let you know if that was the problem.
Re: 6 Pack [Re: 440_dup77] #927159
02/13/11 09:31 PM
02/13/11 09:31 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
One thing - check the fuel pump PUSH ROD. They've been known to wear and not push the pump enough to get sufficient gas into the carb while cruising.
Re: 6 Pack [Re: Sixpak] #927160
02/13/11 09:39 PM
02/13/11 09:39 PM
mt
mt
Iam writing all this down.
Re: 6 Pack [Re: 440_dup77] #927161
02/13/11 10:13 PM
02/13/11 10:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
good luck! it's probably something simple like the needle/seat.
Re: 6 Pack [Re: 440_dup77] #927162
02/13/11 11:11 PM
02/13/11 11:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you can take it apart,you can put it back together.
Re: 6 Pack [Re: 62maxwgn] #927163
02/13/11 11:12 PM
02/13/11 11:12 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
See.
Re: 6 Pack [Re: 62maxwgn] #927164
02/13/11 11:15 PM
02/13/11 11:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All of these were in pieces a month ago.
Re: 6 Pack [Re: 440_dup77] #927165
02/14/11 08:43 AM
02/14/11 08:43 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Here we go again...time and time again good technical information has been posted on moparts about six paks and other subjects and not one of you saves it or has enough wherewithal to read it and learn something. This is one major reason that a lot of the good talent here fades away into oblivion. If you ever wondered what is wrong with our country this is a good place at times to see the problem firsthand. I bet if a search was done on six paks the following document would be found.
And then there is the bad information and products...I will leave it at that.
While I am chastising the students in the classroom and the people who run this place...I am still looking for the suspension/handling forum...anyone seen it??? It's quite a disservice to us on moparts not to have that section in the forums.
Here ya go children, it's been edited some more.
Print it out and read it several times and get to work.
Here is a guide to tune six packs for street engines. Revised 02-2011
Stroker or non stroker, big block or small block.
Never the final word, but close enough for now, it gets updated from time to time.
This is not for the faint of heart. If you wondered why people shy away from six paks just read on.
I have compiled and rewritten the info contained from within along with my own experience from driving a six pak car with a lot of wow! for many years.
When tuned properly Six pak cars turn on! faster & run far better than single 4 barrel cars. If you want your six pak car to run like it should do the dance and have the right tools to make it happen. Patience must be used throughout the process. Much of the information here can be used on a 4 barrel as well.
Some theory of operation:
Things to Remember
Six pak engines run on the center carb and idle on all 3.
Only the center carb has a acceleration pump
The outboard are always contributing fuel…always
The car must idle and run/drive like a normal car before attempting any secondary action or wide open throttle passes.
Whacking the throttle in neutral to see if the outboards open is not a legitimate test!!!
Overjetting will not allow you to get the idle mixture correct as the jet size does contribute to what happens in the idle circuit. Go read the theory of operation in the Mopar book
Gasoline is flammable and will burn you.
A good vacuum gage, quality tach in the car and dial back timing light/digital tach [snap on timing light with numeric readout].
A good ignition system. MSD, Mallory or FBO mopar box, NO orange boxes or chrome boxes unless you know for sure it is early 80’s vintage. Anything made after 1988 is questionable.
Quality distributor cap & rotor
Firecore spark plug wires
Spark plugs of the proper heat range. Clean and gapped
0.040 mopar box
0.050 msd cd type ignition
Vacuum adv distributor with heavy enough springs to hold advance until 1200 rpm.
The distributor phasing has been checked and corrected as necessary
THIS IS IMPORTANT
Distributor vacuum port on carb disconnected and plugged at carb
Mopar viscous fan package
ATTENTION -195 degree thermostat- ATTENTION
THIS IS IMPORTANT
60%water-40% coolant with a bottle of water wetter
Pay attention here: If you run a lower temp thermostat, raw fuel will collect in the intake. That fuel burns off in the cruise mode and the air-fuel mixture goes lean.
This is transparent unless the a-f ratio is being monitored with a wideband a-f meter
There will be problems getting it to idle and drivability.
Make sure the timing is 15 - 18 deg btdc [advance] at idle. THIS IS IMPORTANT
Set the timing marks at 15 btdc and align the rotor with the cap-this is one reason the phasing was checked.
Car in neutral-auto or 4 sp, emergency brake set.
A good quality vacuum gage is required
Connect vacuum gauge to direct manifold vacuum source.
The heat crossover should be blocked on big & small blocks
Note: in temps below 40 degree it will take a good while to get the car warmed up. Block heaters will eliminate the long warm ups.
Automatic cars: be sure there is enough stall in the torque converter or the car may be a real pig idling in gear and have poor get-up & go.
Beware of mopar orange ignition control boxes that retard the timing etc. Orange boxes built after 1988 tend to have issues.
Preparation:
Outboards: Remove the lead plugs
Set the outboards idle adj screws out 1/8 turn ccw THIS IS IMPORTANT
Be careful when seating the idle screws to set them before the 1/8 setting. Gently is the word. If you look inside the carb bore you will see the needles poking in ever-so-slightly. They should be equal.
Install the BLACK springs – Just do it, ignore everything else you have read.
Yes I repeated that, explained way below
I you have the jetable metering plates, If so read their instructions and follow them.
Center carb
Set the center carb idle adjustment screws at 1.5 turns out [ccw] THIS IS IMPORTANT
Be sure to adjust the idle screw until the throttle blades are closed and the transfer slot is exposed no larger than a square. [Carb will have to be off the car to see this] You only want about .040" of the transfer slots exposed below the throttle plates. If the idle screw is adjusted too high, you will be into the transition circuit, exposing too much of the vertical rectangular slot. Many times the idle screw is adjusted incorrectly to compensate for other issues. This puts the carb into the transition circuit and at that point you have no mixture control on the center carb.
If you have new carbs(untouched) they will have 62 jets in the center carb & a 6.5hg power valve. Starting point jetting stock 340 use 62’s, highly modified or stroker use 64’s, big blocks start with 64, stroker 65.
You must know what power valve is in the center carb. Typically a 6.5
Reminder 195 degree thermostat required.
Temporarily change out the brass sight plug on the fuel bowls (all 3) with Holley’s clear sight plugs, to see the float level without no gas spills
Do not use an idle solenoid; a properly tuned car will have no “run on” issues
Factory style linkage, no progressive/ mechanical linkages!
Fuel pump: Carter street pump.
Factory style fuel lines only.
Use rubber hose only for tuning purposes.
Fuel filter should be in the stock location.
Make sure the linkage is set properly. The rods should fall into the hole on the carb lever. Do this after you set the throttle blades on the slot.
Check the linkage for any binding, manually open the center carb to wot and see if the secondaries will rotate open. Have an assistant floor the gas pedal and check for wide open throttle
Start car
allow engine to reach operating temp. Set idle to 1000 rpm
Fuel level adjustment THIS IS IMPORTANT, this is best done idling at 1000-1100 rpm
The slotted screw on top of the needle n seat is just a lock screw,
To adj the float level loosen the lock screw to rotate the seat nut,
Turning the adjuster nut counter clockwise will RAISE fuel level in the bowl,
Clockwise will LOWER it
Make only small 1/2 turns and wait 3 or more minutes so the fuel levels off before rechecking level. Patience!!
Center carb the fuel level is at the bottom of the sight plug hole
Secondaries just starting to come over the bottom of the sight plug hole
This is critical so get it right.
Set idle for 900 rpm
If the car won’t idle:
Is engine vacuum reading at least 2 hg higher than the power valve rating? If ok proceed, if not correct power valve issue and proceed.
Note some engines only pull 5 hg of vacuum so use a 2.5 power valve.
Advance the initial timing a bit to see if it helps idle.
Be sure operating temp is 195-210
Be sure some fool did not put light springs in the distributor.
Now set the initial timing to where it wants to be. Somewhere between 10-20 degrees BTDC. The engine will tell you by increasing vacuum and rpm at this point. In some applications the engine does not care, so set it to 12-14 degrees BTDC.
Chart:
Cams with 106-degree ctrlines seem to like initial timing set at 16-22 BTDC
Cams with 108-degree ctrlines seem to like initial timing set at 12-18 BTDC
Cams with 110-114 degree ctrlines seem to like initial timing set at 8-14 BTDC
Re-Set the idle rpm for 900-See if you have "control" over the idle mixture screws on the ctr carb.
Using a good vacuum gage adj center carb mixture to highest reading of vacuum.
This is where the digital[numeric readout] tach is better than the vacuum gage.
If you do not have control over the idle mixture you have issues that need to be taken care of before proceeding. Overjetting contributes to this
Typically if you have the center carb idle mixture screws between 1 to 2 turns ccw
you do not have to adjust the outboard idle mixture any further. Starting with the front carb, adj the mixture screws one at a time 1/16th turn ccw, after turning each screw wait and see what the engine vacuum and rpm do. Obviously if you have a wideband a-f gauge you will see what is happening.
If you are 2 turns out on the ctr carb idle mixture and the idle is still too lean, the outboards need to contribute more fuel to the idle. Open the idle mixture screws another 1/8 turn ccw. Now they will be out a total of ¼ of a turn ccw. Now go back and rset the idle mixture and rpm.
If the idle is too rich no matter what you do…Most times you are over jetted or you have other issues....
Over jetted carbs will have poor idle control. At idle fuel flows from the float chamber thru the main jet then into a the small angular but horizontal passage that leads across to a vertical passage and onto the idle feed restriction where it is mixed with the air coming in from the idle bleed. Remember this. Do not over jet!
Beware of other issues such as poor intake sealing, carb gaskets backwards, the wrong pcv valve, a vacuum leak from the brake booster or other places, wrong pwr valve, wrong thermostat etc.
Recheck idle rpm and set to 900
Drive car like a normal person, no wide open throttle. Is the car rich? Jet down 2 steps until you find the min jet size. You will know when you are lean as you will have no power.
Now reset the initial timing again. Somewhere between 10-20 degrees BTDC. The engine will tell you by increasing vacuum and rpm some point and then falling off. In some applications the engine does not care, so see chart.
Re-Set the rpm for 900-See if you have "control" over the idle mixture screws. Using a good vacuum gage adj each mixture screw to highest reading of vacuum. If you have a wideband afr meter set to 14.7 See how close you are between the vac gauge and af meter.
Recheck idle rpm and set to 800-950 depending on engine build, hook up vac adv and make sure car still runs/drives properly.
How do you know when you are "there”?
If the car gets up and goes seamlessly you are there
The engine when hot soaked restarts immediately without touching the throttle
The car will idle at 700-900 rpm in neutral and the response is crisp.
There is no smell of raw gas in the exhaust.
The bottom of the intake is not soaked with fuel. Open a carb and look in
The spark plugs are clean and white.
The engine when cold starts easily, runs and drives smoothly from the get go.
When the engine is rev’d and the throttle released it immediately returns to idle.
The vacuum advance is hooked up and the car drives well.
OK if you made it this far it’s time for the Secondaries
The reason you put the black spring is to delay the opening of the secondaries until the engine is ready for it. The engine will run fine on just the center carb till at least 3000 rpm. The air fuel mixture spikes lean when the secondaries open, but at higher rpms this is transparent and has no affect on performance. The opening of the secondaries should be seamless, but very apparent and usually scary to the uninitiated.
Some cars may enjoy a lighter spring.
The secondaries rods should be disconnected and removed and the vac signal blocked.
Please do this safely and with regard for others….
Go out and drive the car on the center carb and determine what rpm the car starts to fall off in power. Take note.
The car should have a ton of power just with the center carb.
Be sure to several wot runs.
Reconnect carb linkage and vac lines, be sure to set the length of the rods properly.
Now go for a drive and see what rpm the six pak hits.
Hold first gear or 2nd gear, run up to 2500 rpm and floor it. What should happen is the secondaries open without any hesitation and the cars gets up and really goes.
The long vacuum hoses for the outboard carbs need to be exactly the same length.
Pulling a vacuum on the hose should make the vacuum pod open the throttle blade and hold a vacuum
The best way to dial in the secondary air fuel ratio is with a wide band air fuel meter.
A fine tuned seatofthepantsometer and spark plug reading will work for the more experienced.
If you made it this far and the car is bogging when the six pak opens you need to go back and recheck starting at the top. Bogs are usually from the secondaries opening too soon!!
Notes:
Automatic cars with too tight of a converter will cause significant idle rpm drops when in drive, the car will not run at it’s full potential so be sure to use the correct converter for the application.
Some cars like staggered jetting.
If car spits fuel out of the vent[s] it means the o ring on the needle seat is bad.
It’s always easier to remove the front carb for rejetting.
Tape over intake and make sure there is never any unaccounted for hardware
If the initial timing exceeds 12 degrees BTDC with a MP distributor typically the advance curve will need to be modified so the total timing is not more than 34 degrees BTDC.
Chart to shorten the slots if you have a non adjustable mopar distributor.
Distributor degrees X 2 + initial= total
32-36 total advance typically
No adv till 1200
Slow rate until all in at 24 - 2800 rpm, heavier cars like later than sooner.
dist. degrees / slot size
6.............. .340
7............... .355
8............... .375
9............... .390
10.............. .405
11.5 ........... .420
12.............. .435
13.............. .445
14.............. .460
15.............. .475
16.............. .490
17.............. .505
18.............. .520
Page 2 of 3 1 2 3
