Re: Reverse Flow cooling plate from Indy
[Re: bigtimeauto]
#926685
02/14/11 12:22 AM
02/14/11 12:22 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
FWIW the only reason I switched was the front mount distributor. With that I was unable to run the standard type pump and the reverse cooling Meziere was the chaepest easiest fix.
[Re: Al_Alguire]
#926686
02/14/11 07:15 AM
02/14/11 07:15 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I have reverse cooling with Indy heads and drilled for entrance between the center exhaust ports. Since I have an external pump, it was just as much trouble building the set up for reverse flow as it was for normal circualtion. Seems to work great. As far as the pump goes, one of the best buys I have made in this hobby is the Craig Davies EWP set up. http://www.daviescraig.com.au/Electric_Water_Pumps-list.aspx
Plynouth VIP '67 TT IC EFI
[Re: AndyF]
#926689
02/14/11 01:50 PM
02/14/11 01:50 PM
Posts: 1,369 Ohio
3404
Ohio
Looks good. You did a nice job making up those hoses.
Thanks, the short one from the pump to the block was a %$#*@, I had to give the 45 a little tweak and I'm still not too happy with it. Good thing is if I think the reverse flow doesnt help any I can always switch the hoses around and run the standard flow.
Nice job on the blocks and distributor plug Andy, nice looking parts.
[Re: bigtimeauto]
#926691
10/20/13 12:10 PM
10/20/13 12:10 PM
Posts: 245 regina sask
nitrousr
regina sask
here:
Does anyone have a prt number on this pump? Also a measurement of how much it sticks out from the motor plate?
[Re: nitrousr]
#926695
10/20/13 10:02 PM
10/20/13 10:02 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I run one on my 557 and NO issues what so ever . I like the idea of running water to the heads first. I got mine through Mancini and came with the chevy pump. ![](http://i1131.photobucket.com/albums/m553/debobs557/IMG_8937.jpg)
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
