Re: Reverse Flow cooling plate from Indy [Re: bigtimeauto] #926685
02/14/11 12:22 AM
02/14/11 12:22 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW the only reason I switched was the front mount distributor. With that I was unable to run the standard type pump and the reverse cooling Meziere was the chaepest easiest fix.
Re: Reverse Flow cooling plate from Indy [Re: Al_Alguire] #926686
02/14/11 07:15 AM
02/14/11 07:15 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I have reverse cooling with Indy heads and drilled for entrance between the center exhaust ports. Since I have an external pump, it was just as much trouble building the set up for reverse flow as it was for normal circualtion. Seems to work great. As far as the pump goes, one of the best buys I have made in this hobby is the Craig Davies EWP set up. http://www.daviescraig.com.au/Electric_Water_Pumps-list.aspx
Plynouth VIP '67 TT IC EFI
Re: Reverse Flow cooling plate from Indy [Re: jyrki] #926687
02/14/11 11:52 AM
02/14/11 11:52 AM
Ohio
3404 Offline
3404  Offline
Ohio
I couldnt get a hood/scoop on without using a cowl because of the stock location distributor height so I had to go to a belt drive distributor.
I used Andy's water blocks for mine.
Re: Reverse Flow cooling plate from Indy [Re: 3404] #926688
02/14/11 01:05 PM
02/14/11 01:05 PM
AndyF Offline
AndyF  Offline
Looks good. You did a nice job making up those hoses.
Re: Reverse Flow cooling plate from Indy [Re: AndyF] #926689
02/14/11 01:50 PM
02/14/11 01:50 PM
Ohio
3404 Offline
3404  Offline
Ohio
Thanks, the short one from the pump to the block was a
%$#*@, I had to give the 45 a little tweak and I'm still not too happy with it. Good thing is if I think the reverse flow doesnt help any I can always switch the hoses around and run the standard flow.
Nice job on the blocks and distributor plug Andy, nice looking parts.
Re: Reverse Flow cooling plate from Indy [Re: 3404] #926690
02/14/11 03:20 PM
02/14/11 03:20 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Hmmmm i like that!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Reverse Flow cooling plate from Indy [Re: bigtimeauto] #926691
10/20/13 12:10 PM
10/20/13 12:10 PM
regina sask
N
nitrousr Offline
nitrousr  Offline
N
regina sask
here:
Does anyone have a prt number on this pump? Also a measurement of how much it sticks out from the motor plate?
Re: Reverse Flow cooling plate from Indy [Re: nitrousr] #926692
10/20/13 01:00 PM
10/20/13 01:00 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
I RUN THE REVERSE FLOW MEZIERE..
http://www.jegs.com/i/Meziere/680/WP307R/10002/-1
[image][/image]
Re: Reverse Flow cooling plate from Indy [Re: 2QUICK4U] #926693
10/20/13 03:15 PM
10/20/13 03:15 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I got to ask a?What or the advantages of running one of these pumps?By cooling the heads first to run more timing or what
Re: Reverse Flow cooling plate from Indy [Re: racerx] #926694
10/20/13 03:49 PM
10/20/13 03:49 PM
regina sask
N
nitrousr Offline
nitrousr  Offline
N
regina sask
Not sure of a cooling advantage but im hoping with the motor on top like the one bigtime runs it might fit between the motor plate and the reverse drive F3 procharger on our new build.
Re: Reverse Flow cooling plate from Indy [Re: nitrousr] #926695
10/20/13 10:02 PM
10/20/13 10:02 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I run one on my 557 and NO issues what so ever . I like the idea of running water to the heads first.
I got mine through Mancini and came with the chevy pump.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
