FinkBeiner on Rocker Ratio vs Lash #926463
02/11/11 03:25 PM
02/11/11 03:25 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
Andy says in page 73 of his book that if lash is 15 with a 1.5 then it should be adjusted to 17 for a 1.7 rocker arm.
If mine was 22 with a 1.5 and I use 1.6 ratio rocker arms should I adjust the lash differently?
Re: FinkBeiner on Rocker Ratio vs Lash [Re: GwaiiEagle] #926464
02/11/11 04:41 PM
02/11/11 04:41 PM
AndyF Offline
AndyF  Offline
Yes, it should to 0.023 or 0.024 to provide the same ramp clearance at the cam.
Re: FinkBeiner on Rocker Ratio vs Lash [Re: AndyF] #926465
02/11/11 11:59 PM
02/11/11 11:59 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
Thanx Dude!
