Full exhaust and springs relocated? #926162
02/11/11 11:40 AM
02/11/11 11:40 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
If it can be done, how about some pics of A bodies with full exhaust out to the rear bumper, and the leaf springs relocated, offset shackles too. Thanks.
Re: Full exhaust and springs relocated? [Re: 4404dart] #926163
02/11/11 04:41 PM
02/11/11 04:41 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Re: Full exhaust and springs relocated? [Re: 4404dart] #926164
02/12/11 12:36 PM
02/12/11 12:36 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Thought I would try once more, anybody with full exhaust and bigger tires/springs relocated?
Re: Full exhaust and springs relocated? [Re: 4404dart] #926165
02/12/11 01:02 PM
02/12/11 01:02 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I'm sorry that I don't have a picture,but I can describe it. My 67 Barracuda has the springs under the frame rails with full exhaust. I have TTI and use 2 1/2" tail pipes. I don't know about a stock fuel tank because I put in a 15 gal tank in the trunk. The exhaust fits fine. Previuously I has a poly gas tank dropped through the floor and I had only 1/2" clearance between the spings, tank and pipes. If you are using a stock tank, I would not use 3" tail pipes. 3" through the mufflers and 2 1/2 " tail pipes work great.
Re: Full exhaust and springs relocated? [Re: 4404dart] #926166
02/12/11 01:08 PM
02/12/11 01:08 PM
I bought a 65 dart roller w the (super stock) springs relocated into the subframes w (I'm assuming) the MP square boxed deal w the angle cut on one end and the rear shackles welded on/hanging from the rear subframes and there will be no room for a stock width tank and the PO did not mini tub it at the same time so the gain was not that much and I'm going to put the springs back to normal so I can get a stock tank in there & be able to run tailpipes along side it
Re: Full exhaust and springs relocated? [Re: 4404dart] #926167
02/12/11 06:34 PM
02/12/11 06:34 PM
QLD Australia
Keith Black® Offline
QLD Australia
my B body has exhaust to rear, 345 wide tyres & most the remaining space taken up wit suspension...
BIG job!
Darren Beale
Keith Black Racing Engines®
Re: Full exhaust and springs relocated? [Re: Keith Black®] #926168
02/12/11 09:48 PM
02/12/11 09:48 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Good info and some thinking outside the box.
Re: Full exhaust and springs relocated? [Re: 4404dart] #926169
02/12/11 11:25 PM
02/12/11 11:25 PM
QLD Australia
QLD Australia
we had to do major work to get the exhaust over the rear axle.
3.5in pipes required we fabricate a whole new raised hump over the rear axle & into the boot floor.
Pipes were too large to run in the original location with my combo [which is a street car] I really need 4 mufflers to keep it as quiet as possible [which will still be noisy]. Pipe routing has a few twists (all mandrel bends) the use of V-Clamps for easy section disassembly.
Darren Beale
Re: Full exhaust and springs relocated? [Re: Keith Black®] #926170
02/13/11 03:29 PM
02/13/11 03:29 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
My 68 Dart...
Butch
