Re: A-body 73up disk swap, How much does track width change [Re: Jim_Lusk] #925665
03/08/11 02:37 AM
03/08/11 02:37 AM
Klamath Falls, Oregon
Dartslantsix Offline
Wrong. The k-member dimensions are exactly the same from 67-76.
I just leafed through Tom Condran's book. He states that all A-Body lower control arms are the same length. If what you're saying about the K-frames is true, does the extra width come from the knuckles?
Maybe I've misunderstood something.
Re: A-body 73up disk swap, How much does track width change [Re: Dartslantsix] #925666
03/08/11 03:36 AM
03/08/11 03:36 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The extra width comes from the location of the rotor on the spindle.
Re: A-body 73up disk swap, How much does track width change [Re: Jim_Lusk] #925667
03/08/11 09:18 PM
03/08/11 09:18 PM
Thanks for the clarification.
Re: A-body 73up disk swap, How much does track width change [Re: Fab64] #925668
03/08/11 09:42 PM
03/08/11 09:42 PM
Under My Car
Mopar_Country Offline
Under My Car
Actually, I have not personally noticed the extra width up front, and I was surprised when I read it here. That's why I decided to ask about it.
I just looked on-line, and found the following track widths:
1967 Barracuda - front 57.4, rear 55.6
1975 Dart - front 59.1, rear 55.6
This matches what RobX4406 said, above. Assuming this is correct, the rear track did not change, but the front track on the 73-76's is wider by .85" on each side (that's just under 7/8", which is .875").
Jim, all three of your cars look fine to me. Are they each running the same width wheels in front and back?
Sources:
1967 Barracuda
1975 Dart
My car is a 74 and there is a noticeable difference from front to rear track when standing behind it. I kinda wondered why myself.
Re: A-body 73up disk swap, How much does track width change [Re: MileHighDart] #925669
03/10/11 01:46 AM
03/10/11 01:46 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Some trivia...
> When the "bulged 1/4 panel" A-body came out in 1970 (Duster), the engineers wanted a wider axle housing. Bean counters quashed it. Everybody commented on how "lost" the rubber looked on 1970 Dusters (rear).
> Then, in 1973, when the 4.5" BC / slider brakes (wider track setup) came out, the Duster / Dart Sport looked so silly (stock) with front wheelhouses looking "full" and the rears "empty", that there was actually a TSB telling service managers that this visual effect was normal. Which it was.
Comments above, re: basic body dimensions and suspension components unchanged 1967-'73, are 100% correct.
Rick
Re: A-body 73up disk swap, How much does track width change [Re: Rick_Ehrenberg] #925670
03/10/11 01:51 AM
03/10/11 01:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Some trivia...
Rick
Sounds like a 68-70 B body rear would be right at home under one ?
Re: A-body 73up disk swap, How much does track width change [Re: JohnRR] #925671
03/10/11 01:58 AM
03/10/11 01:58 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Some trivia...
Rick
Not that they are really available around here, but the later (VH-onwards) Aussie diff was a tad wider than the earlier ones. I don't have the specs off the top of my head, but I would say about a 1/2" or abit more per side.
My last VG (now 68hemiB's) had a later diff in it, and a factory steel wheel just made the tire about rub the 1/4 panel...
Since the later cars were rounded compared to the earlier cars (sort of like what happened here) they actually did go with a wider diff there though.
Re: A-body 73up disk swap, How much does track width change [Re: OzHemi] #925672
03/10/11 02:09 AM
03/10/11 02:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Some trivia...
Rick
Jeff that car is not the bulged 1/4 A body Ebooger speaks of , they would be duster , demon , dart sport , the car in the pic is the same as the 67-69 A bodies
Re: A-body 73up disk swap, How much does track width change [Re: JohnRR] #925673
03/10/11 02:12 AM
03/10/11 02:12 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I know John...the diff is from a later car I am saying...(which were more bulged like the US ones you mentioned)
Just saying if one of our later cars had the same diff width like the Oz cars had later on...it would have been wider to match the front track.
Re: A-body 73up disk swap, How much does track width change [Re: RobX4406] #925674
03/10/11 04:45 PM
03/10/11 04:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Track
73+ is 59.1
67-72 is 57.4
Wheel track is dependent on wheel width/offset.
From my own measurements the '73-'76 disc setup on a '62-'72 B body puts the wheel mounting surface 5/16" out on each side (5/8" wider total)
Re: A-body 73up disk swap, How much does track width change [Re: John_Kunkel] #925675
03/10/11 08:38 PM
03/10/11 08:38 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
On my 69 dart I run 15x6.5 rallye wheels on the rear with 245/60x15 tires and 14x7 rallye wheels on the front with 235/60 14 tires. I have the later 74/75A disc swap on my car with an 8 3/4 rearend. I dont notice the track difference and that is mostly due to the smaller rim/tire on front but it still looks good By the way "milehigh" your Dart looks really good with those wheels on it
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: A-body 73up disk swap, How much does track width change [Re: MileHighDart] #925676
03/11/11 08:20 AM
03/11/11 08:20 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I noticed it on my 68 Dart. I put a 73 set-up on the front with 15" x 3 1/2" Weld ProStars that were centered on the wheel spacing. My tires rubbed my fenderwell headers. I bought a set of 15" x either 5" or 6" ProStars with a deeper back space and have better clearance. They still rub, but not near as much. I can turn my steering wheel stop to stop now. Before I couldn't.
