Re: Year of trans 904
[Re: VIPERDUST]
#925165
02/10/11 01:05 AM
02/10/11 01:05 AM
RapidRobert
post the # on the machined pad on the pan rail AND look on the ext housing on the side about halfway back on iirc the dr side for a cast 2 digit # such as "77" which'll be the CASTING year & not likely that the ext housing has been changed/not orig so that'll get you close until you post the # & someone can pin it down further
[Re: VIPERDUST]
#925169
02/10/11 02:11 AM
02/10/11 02:11 AM
RapidRobert
Someone other than me will b able to decode them.
[Re: VIPERDUST]
#925171
02/10/11 05:49 PM
02/10/11 05:49 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
3681844 is a 999 not a 904, 5051 is the build date April 27, 1975 so it's a '75 model.
