340 dipstick "won't go in"! #924784
02/09/11 07:07 PM
02/09/11 07:07 PM
kansas city, mo
rave_12000 Offline OP
kansas city, mo
i have a 340 in my challenger. It looks like the hole where the dipstick tube goes in has a metal lining through the whole shaft and lips over the edge. At first i thought it was another dipstick tube that was broken off inside, but this is not the case. It looks factory and another block that i have is the same dealio. i cannot find a dipstick tube that is small enough in diameter to slide in. whats up with this?
Re: 340 dipstick "won't go in"! [Re: rave_12000] #924785
02/09/11 07:13 PM
02/09/11 07:13 PM
Medford OR
FrankenScamp Offline
Medford OR
I had that issue with a chrome mr gasket tube I was using as a quick fix. So much for that. Seems aftermarket stuffs don't all cut the mustard.
Got a stock replacement at NAPA and haven't looked back.
Re: 340 dipstick "won't go in"! [Re: rave_12000] #924786
02/09/11 08:24 PM
02/09/11 08:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm sure you have the old dip stick tube broke off in the block. Try a good size easyout and it will come out so you can put in a new one. Good luck.
Re: 340 dipstick "won't go in"! [Re: Challenger 1] #924787
02/09/11 09:51 PM
02/09/11 09:51 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
The hole size in the block for the dip stick tube is right around .368" ~.370".
Re: 340 dipstick "won't go in"! [Re: Mr340] #924788
02/09/11 09:59 PM
02/09/11 09:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Sounds like you are looking at the flare edge of the broken off tube. you will have to get this out of the block before you can even think about putting the new one in. You may have to sine up the new tube slightly to get to start into the hole when you do get the old broken end out.
Re: 340 dipstick "won't go in"! [Re: MoparforLife] #924789
02/09/11 11:10 PM
02/09/11 11:10 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
sounds like the broken off piece is still in there. BTDT.
After you get the remaining piece out, the new one should go in without too much trouble. If the new tube still fights you, sand the bottom part with emory cloth to very slightly reduce the diameter and try again. I didn't sand mine and tried to tap it in with a hammer, ended up mushrooming the top end of my new tube and it is still not all the way seated.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 340 dipstick "won't go in"! [Re: rave_12000] #924790
02/10/11 08:59 PM
02/10/11 08:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
Snapped a couple pictures of some blocks I have laying around, this is what it needs to look like to be ready for a new dip stick. The broken peice in the block with come out, is the motor in the car?
