Help. 78 440 wont fire after Headunit install #924681
02/09/11 06:19 PM
02/09/11 06:19 PM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
Hey guys. I got a headunit from wal-mart and had my buddy that has be known to do car stereos wire it in. Well The car wont start now. Its a 78 New Yorker with a 440. It has spark,its getting gas it just wont fire. Any Ideas??? Thanks Alot
Re: Help. 78 440 wont fire after Headunit install [Re: 71Polara383] #924682
02/09/11 08:02 PM
02/09/11 08:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you got spark and gas there is no reason for it not to run unless the plugs are gas fouled from being flooded. Your buddy didn't mess with anything under the hood did he?
Re: Help. 78 440 wont fire after Headunit install [Re: 71Polara383] #924683
02/09/11 09:25 PM
02/09/11 09:25 PM
It's getting spark in "crank". What Stump said, I'd check the plugs
Re: Help. 78 440 wont fire after Headunit install [Re: 71Polara383] #924684
02/14/11 02:28 PM
02/14/11 02:28 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
It's got spark in crank position, but apparently not in the RUN position? Bad ballast resistor...
Re: Help. 78 440 wont fire after Headunit install [Re: Sixpak] #924685
02/14/11 04:44 PM
02/14/11 04:44 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Re: Help. 78 440 wont fire after Headunit install [Re: DANA60] #924686
02/14/11 08:42 PM
02/14/11 08:42 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
In the "start" position the ballast resistor is by-passed. So the resistor should not be the problem. Although if it has one of those dual resistors I'm not sure how those are wired. He says it's getting spark.
