Pics: BB Fabricated Valve Covers w/ A-Body Master Cylin
#924621
02/09/11 05:43 PM
02/09/11 05:43 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Can some of you guys post of pics of your BB Fab Valve Covers with the stock A-Body Master Cylinder. I'm curious as to how much clearance I would have if I invested in some. Thanks!
Adriel Paradise Substation Design Engineer III
Re: Pics: BB Fabricated Valve Covers w/ A-Body Master Cylin
[Re: Adrielp]
#924622
02/09/11 07:11 PM
02/09/11 07:11 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I didn't have any problems with the 440Source covers on my DartSport.
[Re: ProSport]
#924623
02/09/11 07:21 PM
02/09/11 07:21 PM
Posts: 1,269 Way out in the sticks of Weste...
DusterDog
I don't have any pictures, but if you are running a solid cam, I would suggest using an off-set mount on the master cylinder to make it a little easier to remove, & re-install them.
"I've upped my horsepower, so...... UP YOURS!!!"
[Re: Adrielp]
#924626
02/09/11 07:53 PM
02/09/11 07:53 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
No pics,but I use the Moroso aluminum covers with the late model Mopar M/Cyl,and I can take the cover off easily.
[Re: Chris2581]
#924627
02/09/11 08:07 PM
02/09/11 08:07 PM
Posts: 577 Arkansas
Adrielp
Arkansas
By the way, we have 1972 Plymouth Duster. Just upgraded to EZ heads as well. Should be track ready in two weeks. Will have initial start up video as well. I've got my eye on those KMJ Performance Valve Covers( http://www.kmjent.com/cart/product.php?productid=526&cat=10&bestseller=Y ). Just hate that no one places the breathers up front on both sides but I like the longer bolts. I'm really worried about the breathers more than anything.
[Re: ProSport]
#924628
02/09/11 08:14 PM
02/09/11 08:14 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Man...that "looks" like a tight fit...no leaks, etc? Your happy with those?
[Re: DusterDog]
#924631
02/09/11 09:53 PM
02/09/11 09:53 PM
Posts: 553 Kentucky
clovis
Kentucky
Those KMJ covers are on ebay for $89 shipped.
As far as the master cylinder I used a 4 wheel disc brake unit from a '95 Mustang - 1 1/16" bore. It works out good for use with fenderwell headers as the lines go to the inside and keep them off the top of the headers. I mounted it on the top two holes, which helps with the valve cover clearance. I had to clearance the hole in the firewall just a tad and drill a new hole in the pedal for the pushrod (which also increased the leverage), but overall it works very well. I covered the open hole in the firewall with a piece of aluminum that I just carried upward and used as a heat shield.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: Adrielp]
#924632
02/09/11 10:53 PM
02/09/11 10:53 PM
Posts: 31,050 Oregon
AndyF
Where can you get the off set mounts from?
Mancini has been selling offset MC adapters for a long time. Mopar Performance has offset mounts for the old cast iron master cylinders, Mancini also has them for the modern aluminum master cylinders.
[Re: Quicksilver440]
#924635
02/09/11 11:39 PM
02/09/11 11:39 PM
ProSport
Akron, Ohio
It was tight but no problem with a 1/4" drive ratchet and short extension. No leaks, I liked those covers alot. My purple Dart looks just like ARI440's photo, very tight with the Indy valve covers.
