Page 1 of 3 1 2 3
engine diaper at indy #924462
02/09/11 03:10 PM
02/09/11 03:10 PM
north west, IN
larry890 Offline OP
larry890  Offline OP
north west, IN
Will they be inforceing the use of a oil containment device for the 10.0- 9.0 class at the friday night drags in indy this summer?
Re: engine diaper at indy [Re: larry890] #924463
02/09/11 03:37 PM
02/09/11 03:37 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
having talked to josh king at the kokomo meet it is my understanding this will be the case.
although due to the the problems with some of the mopar steering setup as long as some kind of attempt at oil containment is made indy will let it pass tech but don't take this as gospel
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924464
02/09/11 03:46 PM
02/09/11 03:46 PM
north west, IN
larry890 Offline OP
larry890  Offline OP
north west, IN
i'll have to ask hamberger dave if he has any extra' s
Re: engine diaper at indy [Re: larry890] #924465
02/09/11 03:52 PM
02/09/11 03:52 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
6) Oil Containment: All vehicles will be required to utilize an NHRA-accepted lower engine oil-retention device. The lower engine containment device must cover the sides of the block and pan up to one inch of the head mating surface and extend within 1 1/2 inches of the front and rear of the cylinder case area. A belly pan may be used in the lieu of a device attached to the engine. The belly pan must extend from frame rail to frame rail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the technical staff prior to any further runs.
here you go, for me this is doable for the belly pan
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924466
02/09/11 04:01 PM
02/09/11 04:01 PM
north west, IN
larry890 Offline OP
larry890  Offline OP
north west, IN
It just seems like some tracks inforce it and some dont for the slower cars.
Re: engine diaper at indy [Re: larry890] #924467
02/09/11 05:32 PM
02/09/11 05:32 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
yes you need one, if you show up without it you wont be racing.
Re: engine diaper at indy [Re: larry890] #924468
02/09/11 05:47 PM
02/09/11 05:47 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Diapers and or belly pans will be required
Not SFI approved, but something will be needed. I have a diaper on my car, big block...abody....stock suspension and steering....it can be done. Check with Russel or DRE, both well under 200 bucks
Re: engine diaper at indy [Re: joshking440] #924469
02/09/11 05:51 PM
02/09/11 05:51 PM
north west, IN
larry890 Offline OP
larry890  Offline OP
north west, IN
well i guess i better get to work. thanks
Re: engine diaper at indy [Re: larry890] #924470
02/09/11 06:02 PM
02/09/11 06:02 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Cant wait to see you guys at the Track!!!!
Thanks for supporting this!
Re: engine diaper at indy [Re: joshking440] #924471
02/09/11 06:27 PM
02/09/11 06:27 PM
north west, IN
larry890 Offline OP
larry890  Offline OP
north west, IN
we have been looking foward to it all winter. great track, close to home my 2 favorite things.
Re: engine diaper at indy [Re: larry890] #924472
02/09/11 06:53 PM
02/09/11 06:53 PM
ill
dennismopar73 Offline
ill
at what et do you have to have it
and does the weekend bracket racer have to have it
Re: engine diaper at indy [Re: dennismopar73] #924473
02/09/11 08:07 PM
02/09/11 08:07 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
If you come on Friday night everyone has to have one....
As far a bracket guy on Saturday and Sunday, Im not sure
Re: engine diaper at indy [Re: joshking440] #924474
02/09/11 09:05 PM
02/09/11 09:05 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Kurt's comment to me was this year the bracket racers will be ENCOURAGED to have one but it will not be manditory. In 2012 it will be manditory. We haven't had that many oil downs but when it happens...just as well go take a nap.
Re: engine diaper at indy [Re: Mopar Grandpa] #924475
02/09/11 10:54 PM
02/09/11 10:54 PM
Lehigh Acres, Florida
rickstershemi Offline
DRE SPORTSMAN DIAPERS $169.....no reason in hell not to run one
Rickster
Re: engine diaper at indy [Re: rickstershemi] #924476
02/09/11 11:44 PM
02/09/11 11:44 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Rickster
Except for having to have a custom set of headers built.
I lost a freeze plug and almost piled my junk into the wall, I'd like to get a diaper for my next car.
But I do kind of wonder if the diaper would start leaking further down the track when things could have been real bad.
Re: engine diaper at indy [Re: rickstershemi] #924477
02/10/11 12:08 PM
02/10/11 12:08 PM
north west, IN
larry890 Offline OP
larry890  Offline OP
north west, IN
will the one for 169 burn if it touches the header tube?
Re: engine diaper at indy [Re: larry890] #924478
02/10/11 09:01 PM
02/10/11 09:01 PM
Probably....but Dennis does a great job custom fitting and using fire-retardant materials @ a very fair cost.....then there's the belly pan route No matter.....it's a good rule and could save your car and better yet your life or someone else's
Rickster
Re: engine diaper at indy [Re: rickstershemi] #924479
02/10/11 11:00 PM
02/10/11 11:00 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
just buy the diaper. 200 dollars is better than replacing the hole car or even the car you may hit and total there car too.!ive seen as slow as 10 sec cars, crash because of the not having a diaper i dont know why this an issue.
Re: engine diaper at indy [Re: joshking440] #924480
02/12/11 11:26 PM
02/12/11 11:26 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
Can anyone post a picture
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924481
02/14/11 11:32 AM
02/14/11 11:32 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Page 1 of 3 1 2 3
