Page 2 of 3 1 2 3
Re: engine diaper at indy [Re: larry890] #924482
02/14/11 11:43 AM
02/14/11 11:43 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
what do you think of this
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924483
02/14/11 11:43 AM
02/14/11 11:43 AM
ill
dennismopar73 Offline
ill
ok not familar with 10,0 / 9.0 bracket at indy
i have a low 10 sec car, run just brackets with.
do we need to have a blanket/ belly pan to run
indy???
last i knew this was for the super comp/ super gas guys
not the weekend warrier??
Re: engine diaper at indy [Re: QWK_ENUF] #924484
02/14/11 03:45 PM
02/14/11 03:45 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
#2
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924485
02/14/11 03:58 PM
02/14/11 03:58 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
perfect
Re: engine diaper at indy [Re: QWK_ENUF] #924486
02/14/11 04:11 PM
02/14/11 04:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Not trying to be a pain on this, but are you starting this engine off the blower like the big boys?
Re: engine diaper at indy [Re: RodStRace] #924487
02/14/11 06:20 PM
02/14/11 06:20 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Tommy, is that a home made diaper ? or did you buy that ?
Re: engine diaper at indy [Re: CRT] #924488
02/14/11 08:05 PM
02/14/11 08:05 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
home made and is in progress as we speak
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924489
02/14/11 08:51 PM
02/14/11 08:51 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
I want 1!!
Re: engine diaper at indy [Re: MoparPitBull] #924490
02/14/11 10:47 PM
02/14/11 10:47 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So is there a spec on the type of material that has to be used? Does it have to be absorbent or just contain any liquid? fire proof ? Does the drag link through the pan cause a safety concern as there would be a sizable hole in the diaper?
Re: engine diaper at indy [Re: rowin4] #924491
02/14/11 10:55 PM
02/14/11 10:55 PM
Connecticut
biginchmotor Offline
Connecticut
Interested to know the cost of one where the center link goes through the oil pan. I have a Charlies pan on my Barracuda. Anyone else have a similar set up as me??
Re: engine diaper at indy [Re: biginchmotor] #924492
02/14/11 11:12 PM
02/14/11 11:12 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
all i have seen seem to be for flat bottom drag style diapers with no provision for motor mounts,center sump pans, k-member mopar style rear steer cars. god forgive if you have a tube for the center link.
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924493
02/15/11 12:15 AM
02/15/11 12:15 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
there is no spec on the material that it is made of. You do have to line the bottom with an oil absorbant material. The stuff russler sent me was just the typical white fabric you see at every factory absorbing oil under a machine.
Mine had a hole in it for a center link...it was 158.00 from russler
Re: engine diaper at indy [Re: joshking440] #924494
02/15/11 12:22 AM
02/15/11 12:22 AM
ill
ill
i thought they had to be sfi/ ?
in order to use or run a diaper??
what are the leagalities as to what the n h r a allow /not allow??
of a home made vs whom ever
Re: engine diaper at indy [Re: joshking440] #924495
02/15/11 12:43 AM
02/15/11 12:43 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
for 158 bucks and get a custom one to your specs from a drawing with dims. is cheap !
Re: engine diaper at indy [Re: BobsProFab] #924496
02/15/11 08:56 AM
02/15/11 08:56 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
CAN SOMEONE POST A PIC or at least some contact info for russler
WAXER
Re: engine diaper at indy [Re: joshking440] #924497
02/15/11 09:00 AM
02/15/11 09:00 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
how did they seal the diaper around the centerlink
WAXER
Re: engine diaper at indy [Re: QWK_ENUF] #924498
02/15/11 10:00 AM
02/15/11 10:00 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
www.russlerii.com is his website
There are classes that require sfi certs on diapers, just non of us apply
We are not enforcing a rule put in place by nhra, we are enforcing a rule put in place by the track.
They way russels worked around the steering link is it had velcro flaps that partially sealed around the whole. Not perfect but it would work to a certain degree
I truly appreciate everyone taking the time to mess with this and figure it out so they can come race with us!
Re: engine diaper at indy [Re: joshking440] #924499
02/15/11 11:47 PM
02/15/11 11:47 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
So much for me and the 10.0 stuff .....My new car is officially for sale, I`ve had enough
I can`t afford this crap anymore
Re: engine diaper at indy [Re: Blown71X] #924500
02/16/11 12:33 AM
02/16/11 12:33 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Sad to hear you would sell your car over a diaper. Even though one person has already shown that you can make one at home.
Re: engine diaper at indy [Re: QWK_ENUF] #924501
02/16/11 12:36 AM
02/16/11 12:36 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Think of a shirt sleeve with a strap on the end. The sleeve would be on both sides of the diaper where the drag link goes thru the pan/diaper. Leave enough length in the sleeve on each side for lock to lock turn. tie strap the ends to the drag link. Simple enough to seal up the drag link.
Old Geezer Racing
Page 2 of 3 1 2 3
