Degree a cam without a degree wheel? #923483
02/08/11 12:37 AM
02/08/11 12:37 AM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
I know I know...quit being so cheap!!
but I have a dial indicator to measure lift at the valve, but I don't have a degree wheel. can I just make one from a paper plate or something?
afterall, the numbers on the wheel are not what's important, right? just that you have TDC properly located, right?
how would I do this without a wheel?
(I've never degree'd a cam...obviously! otherwise I'd probably have a wheel!!)
**Photobucket sucks**
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923484
02/08/11 12:43 AM
02/08/11 12:43 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
The numbers are important. TDC is just a starting point. From there you verify that the cam is where its supposed to be (or where you want it) and adjust accordingly.
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923485
02/08/11 12:55 AM
02/08/11 12:55 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Well... teeth on the starter ring will give you some idea. 360 ÷ # of teeth = degrees per tooth.
Boffin Emeritus
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923486
02/08/11 12:56 AM
02/08/11 12:56 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Are you home now? You can use my degreeing tools.
Project 2025, America's Mein Kampf coming Jan.2025
Re: Degree a cam without a degree wheel? [Re: 52savoy] #923487
02/08/11 01:15 AM
02/08/11 01:15 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
If you buy one...do yourself a favor and buy a large diameter wheel, much easier to use than the small ones.
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923488
02/08/11 01:54 AM
02/08/11 01:54 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
if you're going to be that rough just line the dots up & cross your fingers.
Re: Degree a cam without a degree wheel? [Re: Quicksilver440] #923489
02/08/11 02:45 AM
02/08/11 02:45 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923490
02/08/11 03:35 AM
02/08/11 03:35 AM
You would be suprised, if not irritated,by how much 4 degrees of intake lobe position can make on some motors Would you believe .4 (four tenths)ET and 3 MPH in the 1/4 mile 10 degrees retarded(usually less than one tooth on the crankshaft sprocket or gear) will make the motor a absolute pig If the cam is very big on duration(250 + degrees at .050), intake lobe centers are ground close(110 or less)don't take a chance, wait until you can use a degree wheel I have seen flat top B and RB motors need the flat top pistons notched for the old Mopar Street Hemi purple shaft 284 grind
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923491
02/08/11 06:54 AM
02/08/11 06:54 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Here ya go, cheapskate...
http://www.lucasinjection.com/Degree_wheel_100.jpg
http://media.photobucket.com/image/degree%20wheel/inxs-de/ignition/degree-wheel.jpg?o=13
Re: Degree a cam without a degree wheel? [Re: Sixpak] #923492
02/08/11 07:01 AM
02/08/11 07:01 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
LOL
I am so glad I degreed my last cam.
It was like 5-6 degrees off installing it straight up.
A lot of people who just "line up the dots" will never have the inclination, or thought to go back in and degree the cam properly when the motor is a lazy POS. They'll try bandaids in other areas that will never work and throw off the combo even more. Ask me how I know!
For your own hair's sake, use the degree wheel.
Re: Degree a cam without a degree wheel? [Re: POS Dakota] #923493
02/08/11 09:11 AM
02/08/11 09:11 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have to agree, degree it in. Once you figure how to do it, it is a breeze. You will be surprised how much it is off. You will thank all these comments later. My 2 cents.
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923494
02/08/11 09:56 AM
02/08/11 09:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With a fair bit of work you could down load a 360*
protractor and print it out and tape that to a paper
plate.... bigger is better when we talk degree wheels...
a 8" wheel will have .069" between each degree and a
18" will have .150 between each degree so bigger is
better.... as for doing it..... you would be highly
advised to degree it in.... I have seen some gears
way off(really wasnt the gears, was the cam keyway)
Re: Degree a cam without a degree wheel? [Re: MR_P_BODY] #923495
02/08/11 11:51 AM
02/08/11 11:51 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
This worked for me on a Mag motor to at least tell me I'm close. I did this with timing cover and balancer on the engine. IIRC the cam gear has 36 teeth, crank 18. 2:1 ratio. Every tooth on the cam gear is 10 degrees of timing. Put the engine at TDC #1 intake (not compression) stroke. The balancer on Mag motors has 4 slots around it every 90 degrees. Get a tape measure or better a tapestry tape and measure from the #1 mark to the next mark counter clockwise. Cut the measurement in 1/4's and mark the balancer. Each mark is 22.5 degrees. Get your cam card, see when intake opening starts. Pull the #1 intake rocker and as you turn the crank slowly clockwise, watch the pushrod (ideally with a dial indicator, but an eye ball works too). As soon as it moves stop and see where the balancer lines up on the timing cover. The cover has ten degrees of timing marks, so you should be able to figure out if the cam is any wheres near close to opening like the card says. This worked for me when my engine wouldn't run and I found my timing set off 3 teeth. I did the math, figured out how many teeth to turn the cam gear and the engine fired right up. It's not accurate to a single degree, but if your off one tooth, it will tell you.
Re: Degree a cam without a degree wheel? [Re: Devilbrad] #923496
02/08/11 12:57 PM
02/08/11 12:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
In college I was taught the "Isky split overlap method" for those situations where nothing is available, no tools and no specs, and you have no choice but to make do.
It isn't really accurate, it's only slightly better than nothing, I don't like it, but the procedure does exist if somebody would like try it.
Rich H.
Esse Quam Videri
Re: Degree a cam without a degree wheel? [Re: ZIPPY] #923497
02/08/11 01:10 PM
02/08/11 01:10 PM
Thumperdart used that method back when Ziipy, why don't you elaborate on that method, especially for a guy who has a dial indactor and not a degree wheel I know it but it is your post so
Re: Degree a cam without a degree wheel? [Re: Cab_Burge] #923498
02/08/11 02:49 PM
02/08/11 02:49 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I know it too, but its your post. If you dont remember it all I can fill in the rest mike
Re: Degree a cam without a degree wheel? [Re: Sport440] #923499
02/08/11 03:13 PM
02/08/11 03:13 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
how about this, with the motor in the car, line it up dot to dot, and move the cam around till you get the most compression. all you need is a compression tester and probably a battery charger
Re: Degree a cam without a degree wheel? [Re: 70Cuda383] #923500
02/08/11 03:42 PM
02/08/11 03:42 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
If you have an ATI balancer, they are aceptable in a pinch.
8.30's @3400 lbs
Re: Degree a cam without a degree wheel? [Re: sixpackgut] #923501
02/08/11 03:50 PM
02/08/11 03:50 PM
UK
602heavy Offline
602heavy  Offline
UK
........at what point would you stop advancing centreline?
Re: Degree a cam without a degree wheel? [Re: 602heavy] #923502
02/08/11 03:55 PM
02/08/11 03:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
when you hear noises . really, how much advance comes on these timming chains? keep in mind that they are crank degrees and not cam degrees. so its only half of what the old cam bushings used to do in the old days
