Re: is tti exaust worth the money
[Re: pnypwr]
#923003
02/12/11 02:58 PM
02/12/11 02:58 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
well TTI is great unless your car is manufactured wrong like mine was...my 71 barracuda 440-6 the pipes hit everything but the lottery, the tips stuck out to far...a total waste of 1000 bux if you ask me. when I called they told me my car must be manufactured wrong and it couldnt possibly be thier tail pipes...have a local shop bend you a system and put the other 600 bux into something else
I know of a few people that have said that about their installations, some of which that are very experienced with working on these cars. I found that on a couple of them, they tried to do the installation from the collectors on back, while we did ours from the tailpipes on forward. In our case, we did not have to do any cutting, just patience with a pry bar and keeping everything semi-loose to ensure the exhaust was where we liked it before we did the final tightening. It took a few hours to do it with the car up on jackstands. I'm sure it would have been much more pleasant on a lift. I will say the tips are not exactly centered in the rear valance, but that could be from it being a re-pop valance instead of original equipment. Or...a mixture of both.
I don't have any first hand experience with TTI headers, for my wife's car is running Hooker Comps and our other cars have fabricated headers. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: biginchmotor]
#923005
02/12/11 03:47 PM
02/12/11 03:47 PM
Blues_Cuda
St. Louis, MO
Blues Cuda, would you have any pictures of your TTI exhaust system that you could post? Thanks John.
I came across this one if it helps.
[Re: Ramrod39]
#923006
02/12/11 05:12 PM
02/12/11 05:12 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
62maxwgn -
Did you add those cut outs to the TTI sysytem?
Nope,came that way.All TTI. From the back,fit like a glove,no bending ,no prying,just bolted it on.
[Re: Ramrod39]
#923011
02/28/11 10:49 AM
02/28/11 10:49 AM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Glad to see this thread. I am thinking of ordering the TTI system for by '65 B-body. I have to decide:
1) 2.5" or 3"? Motor is a 493, dynoed at 586 HP, 620 ft/lbs 2) H pipe or X pipe? What are the pros and cons of each?
Also, does anyone know if the US Cartool "bolt to the crossmember" driveshaft loop will work with the TTI exhaust (either H or X tube)?
Can't say on a 65, but I have a US Cartool driveshaft loop. It WILL NOT fit an e-body with TTi 3inch pipes and the X-pipe. Perhaps someone else can advise if it works with an H-pipe.
[Re: Vert]
#923012
03/01/11 01:54 AM
03/01/11 01:54 AM
Posts: 9,157 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
I'm not 100% sure yet, but a quick test fit looks like the US Cartool loop is going to fit with the H pipe system I installed.
