Re: Totally Auto only source for light argent in a can ?
[Re: N9671X2]
#922896
02/07/11 11:20 AM
02/07/11 11:20 AM
Posts: 1,083 Long Island, NY
70plymA34
Long Island, NY
Need to redo some 70 ralley center caps, Totally Auto only vendor with this product?
They probably are the only close match in a can. However, you dont have to use the can if you dont want to. Frank Badalson sells this paint for a spray gun and it is a better match than totally auto. If you dont own a spray gun there is propellant and jar set up you can buy if you want to use the franks paint. Its fairly inexpensive to get the setup and the propellant refills are cheap to if you are doing a small job. When my compressor was broken I used this system to spray some small parts and it worked good.
[Re: anlauto]
#922898
02/07/11 12:45 PM
02/07/11 12:45 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
You can go to your local paint supply store. They alway mix up my organisol & argent in spray cans for me. It a little expensive. I think it was like $9.00 or $11.00 a can but I don't have any spray equipment.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#922899
02/07/11 04:33 PM
02/07/11 04:33 PM
Posts: 1,945 Grand Rapids MI
N9671X2
Grand Rapids MI
Appreciate all the responses. I remembered and found this post. https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=3051818&Main=3046730Have to see if I can find the lighter version of this locally. I think a can from Totally Auto would be about 35 bucks shipped. Seems by looking around online, a lot of places refer to what I would just call wheel silver as light argent. Looking for something with the more correct heavy flake with the caps.
