Build sheets and radiator hoses #922233
02/06/11 01:31 PM
02/06/11 01:31 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok, I'm at a loss and I don't have any original sheets here at the house to ck.
But , on a 1969 model. are both the upper(outlet ) and the lower ( inlet) radiator hoses called out on the sheets.
I've been looking at the PDF files of sheets here in the tech archives and I don't see the upper hose specified
It's a 1969 model should it matter
Re: Build sheets and radiator hoses [Re: gtx6970] #922234
02/06/11 01:42 PM
02/06/11 01:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes & no.
The 5/68 revision lists both hoses, the 4/69 revision lists the inlet hose only.
From past discussions, it was believed that the engine assembly came from the engine plant with the outlet hose already installed, so that data was not needed by the plant building the car.
