1974 is the 6th digit engine in the vin #921972
02/06/11 01:01 AM
02/06/11 01:01 AM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
just bought 2 1974 charger sitting inside storage for 14 years both auto slapstick air cars one is a small block but the triple black one has no eng but a bigblock trany in trunk is the 6th digit in the vin the engine and what letter is a 440 or 400 ??not use to cars this new thanks
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 1974 is the 6th digit engine in the vin [Re: sparcy] #921973
02/06/11 01:12 AM
02/06/11 01:12 AM
5th EDIT (M) 400 2bbl (N) 400 4 bbl (P) 400 4 bbl hi perf (T) 440 4 bbl (U) 440 4 bbl hi perf
