Whats the lowest profile air grabber cleaner? #921632
02/05/11 05:58 PM
02/05/11 05:58 PM
Kirkland, Washington
Pacnorthcuda Offline OP
Whats the deepest drop-base air grabber baseplate? Looking for an oval style to fit on a 440 with an EddyRPM in a bulgehood 'Cuda--I am thinking even if I start with the lowest profile I will still have to modify the base.
Any thoughts?
Re: Whats the lowest profile air grabber cleaner? [Re: Pacnorthcuda] #921633
02/05/11 06:36 PM
02/05/11 06:36 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
The 440 base for the Air Grabber will sit the lowest, if that is the look you want. Thre are a bunch of aftermarket ones that may fit better if you don't mind the non stock look
Re: Whats the lowest profile air grabber cleaner? [Re: DANA60] #921634
02/05/11 09:40 PM
02/05/11 09:40 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
This is what I did to a 383 baseplate to fit a 440 with stock intake in a flat hooded Dart. I tried a 440 baseplate, but it still slightly too tall, so I opted for the considerably less expensive 383 base.
Re: Whats the lowest profile air grabber cleaner? [Re: Jim_Lusk] #921635
02/05/11 09:41 PM
02/05/11 09:41 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
That's about a 3/4" drop.
Re: Whats the lowest profile air grabber cleaner? [Re: Pacnorthcuda] #921636
02/06/11 10:29 AM
02/06/11 10:29 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Any thoughts?
Buy whatever you can find that's cheap and plan on modifying it, also member Paint it Black sells fiberglass bases that you could use. For the intake you have you will probably be best cut out he original carb horn and attach the base to a std 14" drop base assembly.
