2001 dodge stratus interchange question #921486
02/05/11 12:21 PM
02/05/11 12:21 PM
Rochester, NY
dusterdood Offline OP
Rochester, NY
I've got a DOHC 4 cylinder 2003 stratus that has some frame damage, and found a 2001 stratus with the 2.4 4 cylinder that has a cracked head. I want to swap my engine into the 2.4 one. It this a direct swap? Will the bellhousing interchange, and the accessories?
Thank, mike
Re: 2001 dodge stratus interchange question [Re: dusterdood] #921487
02/05/11 01:03 PM
02/05/11 01:03 PM
Rochester, NY
Rochester, NY
I looked up on Allpar, and there's two 2.4 L engines. If these are both 4 doors (mine is) they both have the chrysler 2.4s. I'm wondering if anyone here knows if there's other interchange problems from 2001 to 2003?
Thanks in advance,
Mike
