Crank case pressure #921478
02/05/11 12:09 PM
02/05/11 12:09 PM
Las Cruces New Mexico
68post Offline OP
68post  Offline OP
I was wondering if there is a difference in crank case pressure,when useing different oils,I was checking out my car getting ready for the new season when I noticed my intake gaskets were pushing out from the intake almost to the point of causing a vacuum leak. The car still runs strong 9.50 at 144 mph , but kind of baffeled at what could cause this. The only change I made was going to the 20/50 green oil mid season I was using valvoline racing 20/50 and never had this problem.Ive been using the shogun evac system and has always worked great , also been fighting valve cover leaks which also makes me think theres A problem. Anybody have any ideas?
Re: Crank case pressure [Re: 68post] #921479
02/05/11 12:16 PM
02/05/11 12:16 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
How big is the motor? Also, if you are overfilled, that causes blow by. Try reving the motor against while holding the evac hose with a cigarette lighter and see if it wants to blow the flame out. If so, that's your problem.
Re: Crank case pressure [Re: camastomcat] #921480
02/05/11 12:38 PM
02/05/11 12:38 PM
68post Offline OP
68post  Offline OP
Its a 440 with Indy 440-1 heads
Re: Crank case pressure [Re: camastomcat] #921481
02/05/11 12:42 PM
02/05/11 12:42 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If your vac pump is working and you have a valve cover leak, pushed intake gasket? yup, you got a problem. Compression check is in order, flat tappet cam? worn lobe.
Re: Crank case pressure [Re: 68post] #921482
02/05/11 02:42 PM
02/05/11 02:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you run a sealed engine... by rights the only
air coming into the crank case is the air going past
the rings... maybe with the change in oil it doesnt
seal the rings as good as before... if the evac is
still working properly you should be able to pull
the hose off the valve cover and have a vac at revs
(use your finger/thumb to test
Re: Crank case pressure [Re: rowin4] #921483
02/05/11 07:36 PM
02/05/11 07:36 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Shogun system ? believe that's a pan evac only no pump
home of the
Sox and Martin Hemi Duster
