victor heads on low deck #920622
02/03/11 10:50 PM
02/03/11 10:50 PM
central illinois
65dodgebob Offline OP
central illinois
anyone running victor heads on low deck block? what are the problems, and is it worth the hassle or is it straight forward? thanks!
Re: victor heads on low deck [Re: 65dodgebob] #920623
02/04/11 11:40 AM
02/04/11 11:40 AM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
I am....the only issue was getting the pushrods in. Mine were from the first batch and supposedly the later ones need less clearancing than mine did. There were MANY trips on and off the block and a bunch of grinding until it went together. FYI mine is a roller cam combo. I used Hughes rockers and they have worked without incident.
Re: victor heads on low deck [Re: marvo451] #920624
02/04/11 05:45 PM
02/04/11 05:45 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
What manifold are you using?
How much power is it making?
Thanks, Don
Re: victor heads on low deck [Re: cudadon] #920625
02/04/11 05:59 PM
02/04/11 05:59 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
VICTOR Intake, 4150 Quick Fuel 1050 carb. It hasn't been on the dyno. 3260 lb. Duster 10.03 at 132.60 mph. Somewhere around 625-650 on Pump gas. As the username says, its a 451.
Re: victor heads on low deck [Re: marvo451] #920626
02/04/11 09:38 PM
02/04/11 09:38 PM
The Great White North
RAMM Offline
RAMM  Offline
Yes there was some pushrod clearancing but nothing that major at all to strap them on a low deck. FYI the Edelbrock Victor 383 manifold almost matched the tunnel ram with a way nicer power curve and power peak. J.Rob
471 Victor Head article
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: victor heads on low deck [Re: 65dodgebob] #920627
02/06/11 02:23 PM
02/06/11 02:23 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
It's do-able on a flat tappet but a whole lot easier with offset roller lifters on the intakes and if you want to go the extra mile on a roller we offset the intake lifter bores to straighten it up even more. I'll even let you do the machine work
Re: victor heads on low deck [Re: RAMM] #920628
02/06/11 02:36 PM
02/06/11 02:36 PM
AndyF Offline
AndyF  Offline
That was a good article. The $8000 budget number made me laugh though. Johnny must have decided that the real number would scare too many readers away.
