First stage is a Holley TOP-SHOT and second stage a 4150 plate system.Both stages at 6psi on pump gas.Looking for help on jet sizes to achieve 80 horsepower on stage 1 and 150 on 2,I run 34 total timing and can pull staged increments out with the MSD retard control box.Additionally if you can nominate how much you would pull out on each stage that would help.
