4.7 strange noises - piston slap? #92043
07/21/08 03:44 PM
07/21/08 03:44 PM
Upper Midwest
Black_Sheep Offline OP
Upper Midwest
The 4.7 in my '02 Ram has always been a little noisey on start up but it seems to be getting worse. It almost sounds like a diesel until it's run for several minutes, then it quiets down as the engine gets to operating temp. The truck is going in next week for some warranty work and I plan to ask the service writer about it. Could it be "piston slap"? If so, is it a common problem with 4.7's? Is there a way to find out if Mopar has a TSB about it?
Thanks, Mark
'69 Plymouth GTX
See you on the street...
Re: 4.7 strange noises - piston slap? [Re: Black_Sheep] #92044
07/21/08 03:59 PM
07/21/08 03:59 PM
Northern Ontario
Hans Offline
Hans  Offline
Northern Ontario
Hey Mark!
Maybe you should replace it with that 440 out of that cheap GTX
I've got a '02 truck with a 4.7 and it's been a little noisy on start up (off and on) for years but never had any problems. Your service tech. is probably the guy to ask about bulletins.
Hans
Re: 4.7 strange noises - piston slap? [Re: Hans] #92045
07/21/08 04:45 PM
07/21/08 04:45 PM
Upper Midwest
Upper Midwest
A good runnin' 440 would make it a nice truck, thats for sure...
Anyone else?
'69 Plymouth GTX
Re: 4.7 strange noises - piston slap? [Re: Black_Sheep] #92046
07/21/08 05:56 PM
07/21/08 05:56 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have a '02 1500 ram with the 4.7.I have what I would call a bit of lifter noise,but it is very slight,just a little bit of ticking.I have 110K on it and it's been a great truck.
Nautilus Racing-
