stainless header bolt? #920433
02/03/11 05:49 PM
02/03/11 05:49 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
does anyone make a 7/16x 1 inch stainless header bolt for my s.b tti headers?all i find are 3/4 ". tti came with 1" so i assume the 3/4 will be too short
Re: stainless header bolt? [Re: mcmopars] #920434
02/03/11 05:59 PM
02/03/11 05:59 PM
NY usa
540challenger Offline
NY usa
7/16 header bolt Do you mean 3/8x 1" If so ARP has them under small block chevy 400-1111 or 400-1112 depending if you want 12 point or 6.
Re: stainless header bolt? [Re: 540challenger] #920435
02/03/11 06:01 PM
02/03/11 06:01 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
maybe thats why im having a problem.what are small block header bolts?3/8 or 5/16?
Re: stainless header bolt? [Re: mcmopars] #920436
02/03/11 06:05 PM
02/03/11 06:05 PM
NY usa
NY usa
3/8
Re: stainless header bolt? [Re: 540challenger] #920437
02/03/11 06:15 PM
02/03/11 06:15 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
ok my bad,thanks
Re: stainless header bolt? [Re: mcmopars] #920438
02/03/11 06:57 PM
02/03/11 06:57 PM
I think the stock SB iron heads(pre magnum) use 5/16, I don't know about any of the after market heads. The BB and 426 St Hemi use 3/8 I'm probally wrong on the SB
Re: stainless header bolt? [Re: Cab_Burge] #920439
02/03/11 07:22 PM
02/03/11 07:22 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
well it would be a magnum head.ill just take it to parts store and see what size it is before i order from jegs
