Dana 60 question #919609
02/02/11 12:29 PM
02/02/11 12:29 PM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
I'm installing 4.10's in a diff. that had 5.13's with a spacer.
I first installed the carrier without changing side shims and
have way to much backlash. Is there a thin and thick 4.10 ring?
What does the series (2,3 or 4) refer to??
Re: Dana 60 question [Re: demonH1B] #919610
02/02/11 12:31 PM
02/02/11 12:31 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Richmond makes "thin" 4.10 Dana 60 gears that must be used with a ring gear spacer or a 5 series carrier.
All other brands of 4.10 gears will work with your 3 series carrier.
Re: Dana 60 question [Re: DoctorDiff] #919611
02/02/11 12:44 PM
02/02/11 12:44 PM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
Thanks Dr. Diff, I think you nailed it. It is a Richmond gear 6900521.
Since I already have this set, and the pinion installed, I can use
the ring, but with a spacer? Not a problem, this car will be for street use only. I wonder if Richmond make a thicker
4.10 ring?
Re: Dana 60 question [Re: demonH1B] #919612
02/02/11 02:56 PM
02/02/11 02:56 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, you must use the spacer.
Richmond does not make a standard thickness 4.10 ring and pinion.
