Drive shaft ---- Aluminum VS Chrome Moly
#919540
02/02/11 10:43 AM
02/02/11 10:43 AM
Posts: 694 Michigan
Super Scamp
Well after looking and hunting down a drive shaft, with the help from Dean at Mancini Racing,he hooked me up with Dyna-tech. The problem I had was my lenght of my shaft 55 1/2 center to center so Aluminum 3.5 dia.1350 ends was the order. Motor 518" 2500lb car dana60 with powerglide in a "A" body. What are you guys running in your A body with glide?
Just One Man's Opinion
Mopar Mafia Racing
Re: Drive shaft ---- Aluminum VS Chrome Moly
[Re: 408strokerdart]
#919542
02/02/11 11:27 AM
02/02/11 11:27 AM
Posts: 694 Michigan
Super Scamp
I guess that us A body guys have a length issue running a glide I'm pushing about 800hp any more I would have to go with a 4"..Or should I change it to 4" now??
Mopar Mafia Racing
[Re: Super Scamp]
#919543
02/02/11 11:40 AM
02/02/11 11:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Did you ask them about the weight difference between a 3.5" moly and a 4" alum and what each will handle
[Re: Super Scamp]
#919546
02/02/11 05:26 PM
02/02/11 05:26 PM
Posts: 694 Michigan
Super Scamp
How many of Moparts Members have a drive shaft longer than 52" and run in the hp range of 800hp?
Mopar Mafia Racing
[Re: Super Scamp]
#919547
02/02/11 06:01 PM
02/02/11 06:01 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
not sure of length, but close to standard length B Body. Mark Williams chrome moly. told it will handle 1000hp. although i'm making much more will never see that load given tires etc.
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Dunnuck Racing]
#919550
02/02/11 08:51 PM
02/02/11 08:51 PM
Posts: 4,213 New York
polyspheric
New York
That sounds backwards - aluminum stays stretched (rods), steel relaxes back.
Boffin Emeritus
[Re: Super Scamp]
#919552
02/02/11 09:38 PM
02/02/11 09:38 PM
MR_P_BODY
The shop that did mine told me to use aluminum because it had better "memory",and would flex and relax back to it's original state.And that moly steel would take more of a hit without twisting,but would not relax back. Keith
Dyna-teck said they would guarantee my drive shaft not to break ,but I was to inspect the shaft and the welds offen.
I went with a moly shaft... got it from dynotech... it still has the original U-joints in it and still feel like new
[Re: polyspheric]
#919553
02/02/11 10:26 PM
02/02/11 10:26 PM
Posts: 16,932 NC
440Jim
NC
Wall thickness and diameter are the design parameters for torque. If designed to stay under the fatique limit, the steel will have unlimited life. Aluminum has no fatique limit, it will always fatigue at any stress; it is just a matter of time.
[Re: 440Jim]
#919554
02/02/11 10:35 PM
02/02/11 10:35 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Ok, here is my info from one of my last logs. I run a 56" X 3" mild steel shaft. I don't know the wall thickness but at 7189 driveshaft rpm I am past *critical speed* and make more HP than you have posted.
I also do something that is text book wrong but tried it this year and have no issues. I run the rear pinion perfectly in line with the driveshaft and have angle in the trans side only.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: ALKYW5DART]
#919556
02/02/11 10:49 PM
02/02/11 10:49 PM
What is being used in 2000 +HP cars? Just asken.
[Re: 440Jim]
#919559
02/02/11 11:57 PM
02/02/11 11:57 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Aluminum has higher elasticity so, all else equal, an alum. shaft will flex more than steel. However, aluminum shafts are thicker so you'll need to do a bunch of math for a real comparison. Either will permanently deform if stressed beyond the yield point.
The Mark Williams critical speed chart has a safety factor built in and is very conservative. Both Wikipedia and Wallace Racing have info on critical speed if you want to see how your shaft shapes up. The short course is that the longer the shaft and/or the faster it spins the larger the diameter needs to be to stay straight while spinning. If it starts to flex too much it becomes unstable both physically and mathematically.
I have a shortened OE 7290 shaft about 50" long and it's been 1.40 60' at around 3300lbs and I've had it over 6500rpm. http://en.wikipedia.org/wiki/Critical_speed http://www.wallaceracing.com/driveshaftspeed.htm
