T/A-AAR power steering hose #919508
02/02/11 08:48 AM
02/02/11 08:48 AM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
Is there a replacement p/s hose available in the aftermarket? At this point I am not completely concerned with a perfect reproduction, just something from a parts store.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: T/A-AAR power steering hose [Re: 11secaarcuda] #919509
02/02/11 09:15 AM
02/02/11 09:15 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Year One lists one.
http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1
But I am sure any good parts supply house can set you up. I have never had any trouble getting proper hoses for these cars. Some of the Hemi stuff with the oddball fittings gets a bit tricky, but otherwise, no problem.
MB
Re: T/A-AAR power steering hose [Re: HPMike] #919510
02/02/11 02:45 PM
02/02/11 02:45 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I would bet the YearOne part is nothing but a parts store part with a higher price tag. I have never seen a correct replacement with the correct crimp on the ends. Most parts store ones will fit and function fine.
Re: T/A-AAR power steering hose [Re: THESHAKERPROJECT] #919511
02/02/11 02:49 PM
02/02/11 02:49 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I should have added that. The parts will fit and function, but won't look 100% correct.
MB
