Re: NHRA Fuel cell and battery rules?
[Re: SLOW67]
#918261
01/31/11 07:47 PM
01/31/11 07:47 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
That's how I did my wife 1968 Barracuda this past spring. I did run the battery cable from the starter to the external shutoff under the car along the frame rails and then just ran the 1 wire from the other side of external shut off up through the trunk floor to the Battery charging post and then over to the battery. But I don't think I've ever seen any rules on where you have to run the battery cable but I haven't had any trouble at the IHRA/NHRA tracks I've ran at, but that doesn't mean it's correct...
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
