Pinion seal replacement #91795
07/20/08 11:45 PM
07/20/08 11:45 PM
Niwot, CO Formerly denn...
dynorad Offline OP
dynorad  Offline OP
I have a 742 center section rear axle with a leaking pinion seal.
1. The FSM says to use a special tool to set seal depth when installing a new seal. Do I need it? Is the a shadetree way to get the seal depth right?
2. Will I be able to replace the yoke after the seal replacement without affecting bearing preload?
3. How do you torque the nut holding the yoke properly?
TIA
Dennis
Re: Pinion seal replacement [Re: dynorad] #91796
07/21/08 01:41 AM
07/21/08 01:41 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
1. Ignore all that and just install the seal. I never heard of seal depth specs.
2. 742 has shims and no crush sleeve so you can't mess up preload. Reinstall nut tight, IIRC service manual says 240 ft lbs.
3. big pipe wrench
Re: Pinion seal replacement [Re: 446acuda] #91797
07/21/08 03:39 AM
07/21/08 03:39 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I think the most important thing to do is to get the right seal. I had a leak on my 742 rear and just picked up a seal from Advance Auto, which uses leather as the inner seal material, and before long it was leaking again.
At the least, get #18880 from NAPA, it is also cheaper than the leather style and is made of neoprene. I have also read on here that the seal Cass (Dr Diff) sells is even better than the NAPA one.
Good news is, as mentioned above, the 742 is a really easy one to change.
Darren
Re: Pinion seal replacement [Re: Ludington1] #91798
07/21/08 08:26 AM
07/21/08 08:26 AM
scratchnfotraction Offline
Dr Diff has the better seal
or the napa one #18880
hold the yoke with a pipe wrench and use a socket on the nut and tighten it up
use some lock tight on the nut also IMO
Re: Pinion seal replacement [Re: scratchnfotraction] #91799
07/21/08 01:39 PM
07/21/08 01:39 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
In the past I have used a scribe and marked the nut and pinion shaft, and counted the exposed # of threads and then just put it back where it was after replacing the seal.
Re: Pinion seal replacement [Re: UCUDANT] #91800
07/21/08 02:36 PM
07/21/08 02:36 PM
dynorad Offline OP
dynorad  Offline OP
Thanks for the great suggestions.
