Pertronics and my old tach
#917902
01/31/11 08:13 AM
01/31/11 08:13 AM
Posts: 267 Santa Clara , ca
ramcuda
Santa Clara , ca
Ok here we go .... has anyone found a way to get the Pertronics kit to play nice with the old factory tack ? or do i have to send out the tack out and have it updated ... I would like to put the car back to the duel point set up later Tanks David
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/ 1970 Superbird <------ Just one big argument/ 1980 Jeep CJ5 <--- Just wheel it/ 2000 Dakota R/T <--- Should Drive it more/ 2001 Dodge Caravan <----- Cant kill it/ 2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!! www.moparalley.org
Re: Pertronics and my old tach
[Re: DAYCLONA]
#917904
01/31/11 08:52 AM
01/31/11 08:52 AM
ramcuda
Santa Clara , ca
Hi Dayclona/mike
so bypass the ballast and replace the coil with what ?
sick of the dancing tack...
and i think thats way it feels like the spark is dropping over 3500 rpms
[Re: ramcuda]
#917906
01/31/11 02:39 PM
01/31/11 02:39 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Dave,....you didn't state what Pertronix Ignitor conversion set-up you have I or II, or III, or the pro billet dist III....as there are varing coils for each set up
As far as the ballast, you can eliminate it, either remove the resistor coil from behind/inside the ballast, and solder a #10 peice of wire into it,(if you want to keep the ballast for "looks" only), or just join the 2 wire ballast bayonet ends together with a double spade electrical connector/stak-on
Tell me what Petronix kit you have, I have their catalog for applications/set-ups
Mike
[Re: SomeCarGuy]
#917908
02/01/11 04:03 AM
02/01/11 04:03 AM
ramcuda
Santa Clara , ca
the deal with the tack is it jumps around it never smooth and i know i dont idle at 2k rpm
ok this is the part # on the pertronics
[Re: ramcuda]
#917909
02/01/11 04:05 AM
02/01/11 04:05 AM
ramcuda
Santa Clara , ca
I just like posting pics
Stock ?
[Re: ramcuda]
#917910
02/01/11 08:32 AM
02/01/11 08:32 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Dave, you have an early Ignitor I series, but your using a stock coil ( 1 ohm/70:1 turn ratio), loose the coil, because it's ohm /turn ratio isn't rated for the Petronix, loose the ballast as described in the other posts,.....make sure the black wire - (neg) is on the - (neg) side of the coil, red + (pos) is on the + (pos) side of the coil and make sure your ignition lead (usually blue wire) from your harness is on the + (pos) side of the coil, these are the wiring pocedures for NO BALLAST in the system,...use a correct Petronix Flame Thrower coil, you'll need a 1.5 OHM/115:1 turn ratio coil,...I'd recommend the epoxy filled Pertronix pn# PNX-40111,....cheapest place for it is Summit Racing, $32,...coil looks factory, the Petronix coils have a built in resistor, if you wire your system without the factory ballast as described, your system will become a true 12 V ignition set-up, right now using the factory coil/ballast with the Petronix your system is actually 9 V or less, and this is possibly creating havoc with your tach/Ign
Few tips Dave, with the Petronix, don't run solid core plug wires, it'll destroy the HallCell, run a premium copper terminal dist cap, not an aluminum, set the HallCell air gap with a plastic feeler gage (.040), never use any metal feeler gage, if you have to trouble shoot the IGN system, never leave the key in the IGN on mode for more than 30 seconds with the motor not running as it will burn out the HallCell, if you have to work on the electrical system, with key on, disconnect the red Petronix (+) lead from the coil
Mike
[Re: DAYCLONA]
#917911
02/02/11 09:13 AM
02/02/11 09:13 AM
ramcuda
Santa Clara , ca
Thanks for that .... Im trying to get it all tuned and running better than good .. we are going to MATS and we really want to run her down the track for giggles ... and then we are going to drive to Spring Fling ... I know she will make it to LA and back ... good tune = somewhat bad mileage...
[Re: ramcuda]
#917912
02/02/11 10:49 AM
02/02/11 10:49 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Interesting question David.
Thanks for bringing it to light for I'm about to order an Ignitor II and get a Flamethrower I (40111) for my Daytona. Never thought about the enhanced ignition and any affects it might have on my factory tach. Based on what Mike has said, my gut says no..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#917913
02/02/11 11:46 AM
02/02/11 11:46 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Troy, If you were to order a Petronix Ignitor II, you need to order a Petronix Flame Thrower II coil, not a I, the Petronix set-ups I,II,III all have specific required ohm/turn ratio values for their coil requirements,....you can run into the same tach problems with an MSD install
I have 2 cars running Petronix and factory tachs, no issuses, plus a few customers cars set-up with Petronix/factory tachs, and no issuses,.....get the proper pcs, and proper installation, you should have no issuses,...
Mike
[Re: DAYCLONA]
#917914
02/02/11 12:27 PM
02/02/11 12:27 PM
hemi68charger
Houston, Tx
Mike
Roger Dodger, that's a big 10-4.... I think I'm getting it now...........
Flamethrower I for my 500 with the Ignitor I, hooky up that tach.
Flamethrower II for my Daytona with Ignitor II, hooky up that tach.
Both instances since they have the 12v Flamethrowers, I'll bypass the ballast resistors with #10 gauge wire (already have one for the 500) to give me that anal OEM look. In both cars, the red wire will be connected to the (+) side of the coil
I will testify, even with the OEM coil now (until I get the Flamethrower I), the C500 starts right up and idles great cold, a noticeable difference.. I can even pop the throttle cold without much to any stumbling. I can only imagine the performance once I get the Flamethrower I coil installed. The Daytona will probably be unbelieveable with that Ignitor II
[Re: hemi68charger]
#917915
02/02/11 02:23 PM
02/02/11 02:23 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Troy for the same money, upgrade to the Ignitor III conversion kit, not to be confused with the Petronix III billet dist., This conversion kit will only fit a single point Chrysler dist,...has increased output over the II, plus has a RPM limiter/cut out you can tailor/select to the RPM range of your liking,...again very straight forward install, and it all fits under the stock cap,....if you can install/set points, you can install this Mike
[Re: DAYCLONA]
#917916
02/02/11 04:58 PM
02/02/11 04:58 PM
hemi68charger
Houston, Tx
To confirm what Mike stated earlier. I emailed Pertronix earlier in the day prior to replying to this thread. This was Pertronix's answer.
Troy,
99 percent of all tachs that trigger of the negative terminal of coil work fine. In some cases, when the tach is not reading properly, a 0.01 microfarad 1000 vdc capacitor can be installed in series between coil (-) terminal and tach.
[Re: DAYCLONA]
#917917
02/02/11 05:20 PM
02/02/11 05:20 PM
Posts: 3,344 Central TX
roe
Central TX
at what point would you recommend going frome the flamethrower II to the III setup? A certain HP level, or street vs strip application?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: RapidRobert]
#917919
02/02/11 10:44 PM
02/02/11 10:44 PM
ramcuda
Santa Clara , ca
wow opened the can up ...lol i think it may be the tack as well,,, but the motor wiring is all new so if there is a bad wire it ...UNDER THE DASH !!!!!
[Re: ramcuda]
#917920
02/06/11 12:09 AM
02/06/11 12:09 AM
ramcuda
Santa Clara , ca
Wow it like a new motor ...well not so much ... but is a lot better .. Tanks a Dayclona
[Re: DAYCLONA]
#917921
04/28/11 04:46 PM
04/28/11 04:46 PM
hemi68charger
Houston, Tx
Troy for the same money, upgrade to the Ignitor III conversion kit, not to be confused with the Petronix III billet dist., Mike
Hey Mike... Just got my Ignitor II from Summit.... Have you heard of MSD making an ignition system like Pertronix, but has a single lead?
