Re: 318 to 360, use same flywheel?
[Re: 68bb]
#917771
01/31/11 12:35 AM
01/31/11 12:35 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
You will need a flywheel for a 360.Clutch will work with either flywheel.
Leave the gun.......take the Cannoli's....Mike
[Re: 500ciDuster]
#917773
01/31/11 01:09 PM
01/31/11 01:09 PM
Posts: 300 Mass
68bb
super street
super street
Mass
[Re: John_Kunkel]
#917775
01/31/11 08:22 PM
01/31/11 08:22 PM
RapidRobert
To use the diagram you need to use trigonometry to find the exact location(s) to drill & the large drill bits are hard(er) (and $$) to come by. You could get the flexplate (iirc B&M 10239 which MAY be disconnected)) to use your 'wheel as is exp if you might go back to a neutral balance (318) eng. EDIT meant to say discontinued not disconnected
[Re: RapidRobert]
#917778
01/31/11 09:20 PM
01/31/11 09:20 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
They might have been the same as the one above, it's been a year so I can't remember...I can do a search and see if I can find it again.
Edit...yup, it's the same one.
[Re: dustergirl340]
#917779
01/31/11 09:42 PM
01/31/11 09:42 PM
RapidRobert
the machine shop would have to do the math to locate em exactly and if we could get that it might be worth it to buy the large drill bit & do it on your drill press & would need a depth mike & some carefull measuring as a regular depth mike does not have a tapered tip to reach the end of your drilled recess. Doing several for friends might make it worth the effort. Last one I had a shop do 20 years (the math & the drilling) ago was $125 iirc. EDIT The more I think about it w Ma's notoriously poor balancing I think I'd want to take the wheel in w everything & have the shop get it all spot on
[Re: 68bb]
#917782
02/01/11 01:56 PM
02/01/11 01:56 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Bought a new centerforce flywheel and clutch last year for the 318. If I were to put together a 360 could I use the same parts? I believe the 318 is an internal balance and the 360 external? Is it just a matter of using a correct balancer or are there other considerations? Paid a lot for the clutch and flywheel and only have about 2000 miles on them.
thanks
I can balance your neutral 318 wheel for 360 for $35 + return shipping. The picture above is 11" truck wheel. Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
