Re: 71 383 and 440 engine bracket differences???
[Re: Blown_Hemi]
#91736
07/21/08 10:14 AM
07/21/08 10:14 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
The rear support bracket for the A/C, mounts to the valley pan hold down, is longer for an RB engine. The bracket is stamped with "RB", at mine is.
thats the difference , didn't realize that the RB was stamped RB , should be fairly easy to find one , i may even have one if you need it .
[Re: mlubahn]
#91737
07/21/08 11:57 AM
07/21/08 11:57 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Heres the bracket that they are talking about. Also your 383 has a bracket on the pass head that the long alt. bolt threads into. You won't need it on the 440.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
