Strength of a 440 Cast Crank? #915868
01/28/11 02:42 PM
01/28/11 02:42 PM
AZ
drdan Offline OP
drdan  Offline OP
AZ
How far has anyone pushed these cast cranks in a 440?
Searched for the answer and found alot of input on billet and steel but couldn't find anything on the cast one's, thanks for the help, Dan
Re: Strength of a 440 Cast Crank? [Re: drdan] #915869
01/28/11 03:22 PM
01/28/11 03:22 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
id say 500hp max no 4psd,no sticky tires, ive seen then bend from launching and tear out mains fron drag racing, but in circle track ive seen guys spin them 7,500 rpm with good results, much lighter
MOPAR OR NO CAR
Re: Strength of a 440 Cast Crank? [Re: hemigod426] #915870
01/30/11 12:41 AM
01/30/11 12:41 AM
NJ
440challenger Offline
NJ
6500 rpm for about 6 years now. 550hp. 3800 lbs
Re: Strength of a 440 Cast Crank? [Re: drdan] #915871
01/30/11 10:31 AM
01/30/11 10:31 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
There was a magazine article on this once.
Conclusion: As said above, a true, dyno'ed, ~500 hp. at the flywheel if you abuse it.
Behind a high stall automatic, even higher.
They're not shabby pieces.
