queston for painters #915784
01/28/11 01:23 PM
01/28/11 01:23 PM
IL . usa
cjs69mope Offline OP
IL . usa
what is the best way to keep from chipping up the paint on all your nice and clean painted up Fender bolts , Door hindge bolts. When you have to intall them and adjust multple times to get the right fit and gaps any tips ?The wrench will chip the paint and then it looks like crap i have been using the masktape under the socket trick but still the paint is somtimes damaged. what other things help with this ? Thanks in advance for the help!
1969 Dodge Charger 1969 Dodge Superbee
Re: queston for painters [Re: cjs69mope] #915785
01/28/11 01:41 PM
01/28/11 01:41 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I've used kleenex, and it helps. Make sure you use a six point, the 12 pt will want to dig in. In the end, you just have to touch some of them up once they're fully installed. Do a good job of that and you won't see anything.
Thats my .
Re: queston for painters [Re: RemCharger] #915786
01/28/11 01:47 PM
01/28/11 01:47 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Didn't someone make some plastic socket/wrench inserts for that, where you go up a size or two then put in the insert?
Re: queston for painters [Re: thehemikid] #915787
01/28/11 01:56 PM
01/28/11 01:56 PM
IL . usa
IL . usa
That would be sweet!
Re: queston for painters [Re: thehemikid] #915788
01/28/11 03:03 PM
01/28/11 03:03 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I did a design of those. Made some prototypes but it still would chip paint off. If you got the insert soft enough not to do damage the inserts were weak enough they did not last. If you do have to do adjustments use an old hankerchief over the bolt and a 6 point socket/wrench. If you have access to an airbrush do touch ups with that.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: queston for painters [Re: sixpackbee] #915789
01/28/11 03:11 PM
01/28/11 03:11 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Paint your car with the fenders and doors bolted on and adjusted already just like the factory did. It's not any harder to paint and your going to have to bolt all those parts on anyway. It has benefits too as to showing fitment problems BEFORE everything is color coated. Things like the hood and decklid I paint off the car. I bolt them on with "temporary bolts" with tape UNDER the washer for adjusting, then when it's all lined up I swap out the bolts one by one for a "colored correct" bolt.
Re: queston for painters [Re: hemi70se] #915790
01/30/11 05:44 PM
01/30/11 05:44 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
A piece of plastic from one of the many baggies used for parts will work well also...Better than paper IMO...
Re: queston for painters [Re: cjs69mope] #915791
01/30/11 11:34 PM
01/30/11 11:34 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I use old bolts with nylon washers under them to protect the paint. After the adjustments are done I replace them one at a time with the painted ones.
Re: queston for painters [Re: PLUM BAD] #915792
01/30/11 11:56 PM
01/30/11 11:56 PM
Detroit, MI
FC7AARcuda Offline
FC7AARcuda  Offline
Detroit, MI
A trick I found that works fairly well is to take a piece of electrical tape and line the inside of a six point socket with it. Leave enough tape sticking out that you can bend it over and cover the end of the socket so that no exposed metal from the socket touches the bolt. Replace the tape every few bolts. Not perfect but definitely minimizes any paint chips.
Re: queston for painters [Re: cjs69mope] #915793
01/30/11 11:57 PM
01/30/11 11:57 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
It all comes down to the proper paint thickness and adhesion on the bolt. Rubber coated sockets help, as well as electrical taped wrenches, and as stated above, nylon washers for assembly alignment.
Re: queston for painters [Re: hemi70se] #915794
01/31/11 12:41 AM
01/31/11 12:41 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Re: queston for painters [Re: FJ5_Fish] #915795
01/31/11 04:38 AM
01/31/11 04:38 AM
Mesa, Az
GETX Offline
GETX  Offline
Mesa, Az
For a professional show appearance, I just wire wheel my bolts to bare metal then make all adjustments and tighten bolts. Wipe bolt heads with wax & grease remover. place a piece of wide masking tape across the back of a socket that would be the approx. diameter of the bolt/washer that you want to paint and strike the tape with a hammer around the edge of the socket to make a perfect hole in the tape. Place tape with hole in it over the bolt/washer that you want to paint. Using masking paper or plastic drop cloths to protect surrounding areas from over spray, apply adhesion promoter (i.e. Bulldog)to the bolt heads and let dry for a couple minutes. Now you can paint all your bolts with rattle cans if you like or I just use my airbrush @ 25-30 PSI with either single stage paint or base coat/clear coat. The final product looks FANTASTIC!!
Just my
Re: queston for painters [Re: thehemikid] #915796
01/31/11 04:49 PM
01/31/11 04:49 PM
Utah
E
Eagleone1983 Offline
E
Utah
Someone did...Eastwood just released something like this. I saw it in my catalog they send from time to time. Not sure if they actually work or not though.
