strut rod bushings? #915573
01/28/11 02:17 AM
01/28/11 02:17 AM
Cali
BullT Offline OP
BullT  Offline OP
Cali
hey all,
i got a poly suspension kit from springs n things and have been installing it. everything was going smoothly until i got to the strut rod bushings. these are not supposed to be hard to get on, right??
the old ones slid right off, but these ones i had to rubber hammer on to get the center metal piece to even move
this is for a 66 coronet, did they give me the wrong size? or am i missing something?
just want to find out more before i try and return them
thanks for any help
Re: strut rod bushings? [Re: BullT] #915574
01/28/11 07:46 PM
01/28/11 07:46 PM
Cali
BullT Offline OP
BullT  Offline OP
Cali
No suspension guys around? Didn't think this would be a very hard question for anyone that has done suspension work
Re: strut rod bushings? [Re: BullT] #915575
01/29/11 09:24 AM
01/29/11 09:24 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Usually the polys are tight.I didnt install them on my 65 but I did use them on the rear springs and the lower control arms.Did you lube them?That makes them slide on easier.I used RMS adjustable rods with heims. Rocky
Chrysler Firepower
Re: strut rod bushings? [Re: BullT] #915576
01/29/11 10:31 AM
01/29/11 10:31 AM
Jensen Beach, Florida
pressureangle Offline
I used Firm Feel's urethane strut rod bushings, they have no center piece. They go right on the strut rod. See if yours fit good without the spacer.
Why do I torture myself so?
Re: strut rod bushings? [Re: pressureangle] #915577
01/31/11 03:54 PM
01/31/11 03:54 PM
Cali
BullT Offline OP
BullT  Offline OP
Cali
Yea they fit fine without the spacer, what is the point of it anyway? I don't want to waste effort on the spacer if I don't really need them
