07 Magnum Mirror Replacement/Door Panel Removal #915428
01/27/11 10:26 PM
01/27/11 10:26 PM
Oklahoma City
Jwilli500 Offline OP
Oklahoma City
I need to replace the Drivers side mirror on my wifes 07 Magnum. Can someone talk me through how to get the door panel off to do this? I'm trying to keep from tearing it up. Any tips hints or suggestions would be appreciated!
Re: 07 Magnum Mirror Replacement/Door Panel Removal [Re: Jwilli500] #915429
01/27/11 10:49 PM
01/27/11 10:49 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
lately they have gotten clever about hiding screws. Look everywhere and pay attention to where you meet resistance when you attempt to pull the panel. On my '01 300m, you need to gently pry off the speaker grill and there were at least one (maybe 2) screws that were concealed behind the speaker grill. Probably another screw/bolt or two hidden in the area where you tug on the door to pull it shut. Many more screws and fewer clips/snaps than older mopars in my case.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 07 Magnum Mirror Replacement/Door Panel Removal [Re: GO_Fish] #915430
01/27/11 11:55 PM
01/27/11 11:55 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
There will be little round panel retainers around the door panel. Gently push in the center round pin in the retainers until they stop about a 1/4 inside the retainer. Do not try to pry the center of the retainers out, you will break them. If you push the retainers to far they will fall inside the door and you will have to dig them out. Just put them back together and use them again. The panel should lift off with maybe a screw in the inside door handle or on bottom of the panel.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 07 Magnum Mirror Replacement/Door Panel Removal [Re: Jwilli500] #915431
01/29/11 12:11 AM
01/29/11 12:11 AM
Oklahoma City
Oklahoma City
Well, Thanks for the info guys! I'm gonna take a stab at it tomorrow. We'll see!
