Page 5 of 5 1 2 3 4 5
Re: when to put screws in the rims for slicks [Re: bigdad] #915401
01/29/11 01:16 AM
01/29/11 01:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would like to hear an engineer tell us just how many lbs of air pressure holds a tire to the bead
I am not but I'm sure it will amaze you
Sorry but I have seen tires come off the rims when
the car was sideways ... your not going to see that
occur on mine ... as to what pressure it takes...
it s a matter of which has the greater pressure...
is it the air pressure inside it or the side loading
of the tire going sideways.
You better start screwing those front tires too
then
LAST COMMENT FOR ME ON THIS TOPIC
STAY SAFE FELLAS
Yeah I figured you'd quit now... since the fronts run
about 45# pressure VS my 6.5 to no more than 7#
with 14" across and thats not even figuring the total
surface area thats on the ground so you better figure
out which has the greater load .... but
your right this IS my last word on this tread
Re: when to put screws in the rims for slicks [Re: MR_P_BODY] #915402
01/29/11 08:36 AM
01/29/11 08:36 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
FWIW I first ran screws on the car when it was running 12's, 29 x 10 Slick on 8 1/2 inch convo pro. @ 10 psi the tyre moved 4 inches on the rim I've done it ever since.
I run tubes now for the extra sidewall strength, it does improve the 60ft's, at least on my car. If I'd been running tubes back then I have no doubt I would have torn the valve out of the tube.
IMHO for the little time and money it costs it's worth doing for the extra insurance, I've also yet to see a car run slower after screwing the tyre to the rim.
Re: when to put screws in the rims for slicks [Re: Tig] #915403
01/29/11 03:38 PM
01/29/11 03:38 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i dont know why some would move and some dont. i mark mine every time they are mounted. i use no lube, just water to seat the bead. the tire is a 11" tread width and 29" tall. i do leave off a brake with a mild 440. best 1/8th of 6.80. the move 1/16 to 1/8 every hit. i'd screew them, but the car is made to look like a street car and i dont want that look. i also run tubes for the time being , since i picked up a screew in one tire. i will also periodicaly deflate the rear tires as to allow the tube to find it's way back where it started.
Re: when to put screws in the rims for slicks [Re: Deepockets] #915404
01/29/11 06:50 PM
01/29/11 06:50 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
Back in the day, my dad always patched tubes and when they got so bad he gave them to us kids to use to float around on the lake.
Re: when to put screws in the rims for slicks [Re: sjs64polara] #915405
01/29/11 07:31 PM
01/29/11 07:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Big tire+quick 60'+low pressure=screws.
I've always ran screws. Didn't bother to mark the wheels or any of that. If it might be beneficial and it can't hurt and it doesn't cost anything, I just do it, but that's me.
I know my 60' improved a bit and became more consistent when I went to 16 screws per side.
Re: when to put screws in the rims for slicks [Re: rebel] #915406
01/31/11 01:02 AM
01/31/11 01:02 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
You can see that the wrinkle is pulling from where the screw is on the wheel.
5 screws around the diameter of the wheel will make for large paddles, but fewer paddles (4 paddles)
this doesn't compare with my pic showing NO screws at all. somethings not right with this theory.
Not sure what your trying to get at here... No your situation won't compare with this set up BECAUSE your not running any screws. Screws serve the purpose of holding the tire where it is, but they also serve the purpose of controlling the "paddle" of the tire.
Re: when to put screws in the rims for slicks [Re: StrokerAspen] #915407
01/31/11 01:27 AM
01/31/11 01:27 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Used to run screws with slicks, now I just glue the drag radials because they use alot more air presure.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: when to put screws in the rims for slicks [Re: 1967dartgt] #915408
01/31/11 01:37 AM
01/31/11 01:37 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Years ago I ran slick's and did not screw the rim's, twice I ripped the stem out, finally drilled and screwed the rim's and have not ripped a tube since, so now you know my opinion.
