69 B Body Fender Mounted T-Signal Location #914562
01/26/11 06:06 PM
01/26/11 06:06 PM
Rockford, IL
foz Offline OP
International Diplomat
foz  Offline OP
Rockford, IL
I'd really like to add these to my '69 RR. Does ANYONE have a template for the CORRECT location of these??
Thanks very much!
Kelly(foz)
Re: 69 B Body Fender Mounted T-Signal Location [Re: foz] #914563
01/26/11 06:17 PM
01/26/11 06:17 PM
Jackson, Mississippi
CornDogsCharger Offline
I've got a 69 RR here at the shop with them on it. I'll try to get some measurements for you and post some pictures from my phone in the next little bit. If not, then I'll have to post the pictures tonight when I get home from work.
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: 69 B Body Fender Mounted T-Signal Location [Re: CornDogsCharger] #914564
01/26/11 06:55 PM
01/26/11 06:55 PM
Utah
E
Eagleone1983 Offline
E
Utah
I'll also post some pics. The main reason is because my car came with these fender mounted turn signals from the factory. However there is a difference between the location of the left fender and right. On the right fender the three holes follow the body line (edge of the top of the fender) in a nice straight line but on the left one the three holes are staight inline with each other but they are not straight with the body line. When you see the pics you'll see what I mean.
Re: 69 B Body Fender Mounted T-Signal Location [Re: CornDogsCharger] #914565
01/26/11 07:51 PM
01/26/11 07:51 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Do they get the low profile ones or the bullet style ones?
Re: 69 B Body Fender Mounted T-Signal Location [Re: foz] #914566
01/26/11 10:01 PM
01/26/11 10:01 PM
Southern Indiana
75RoadRunner Offline
Southern Indiana
Try these guys. There is a lot of tech data and some very knowledgeable guys here.
www.69roadrunner.net
Re: 69 B Body Fender Mounted T-Signal Location [Re: MI_Custumz] #914567
01/26/11 10:06 PM
01/26/11 10:06 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Road Runner would have the bullet in 68 and 69.
Re: 69 B Body Fender Mounted T-Signal Location [Re: rrunner] #914568
01/28/11 01:13 AM
01/28/11 01:13 AM
Rockford, IL
foz Offline OP
foz  Offline OP
Rockford, IL
Okay guys. Thanks!
I'll be waiting for the pics & measurements!
Will you send them to me as well??
kfoz@comcast.net
Thanks again!
foz
Re: 69 B Body Fender Mounted T-Signal Location [Re: foz] #914569
01/28/11 04:16 AM
01/28/11 04:16 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
I used these. Sent by a member showing original installation location. Not the greatest for pinpoint accuracy but close enough. I had success using them.
Re: 69 B Body Fender Mounted T-Signal Location [Re: 70mopes] #914570
01/28/11 04:17 AM
01/28/11 04:17 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Another
Re: 69 B Body Fender Mounted T-Signal Location [Re: 70mopes] #914571
01/28/11 04:17 AM
01/28/11 04:17 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Last
Re: 69 B Body Fender Mounted T-Signal Location [Re: 70mopes] #914572
01/28/11 09:21 AM
01/28/11 09:21 AM
It appears that one or both of the fenders on this 69 RR are not original to the car. They are definitely '69 fenders though, but I can not say which style indicator is correct for a RR. This style indicator is measured 3 inches off the top edge of the fender to the center of the indicator. The lens side of the indicator is 6 inches back from the leading edge. This is on the left fender. The right fender on this car did not have an indicator or holes for one. Hope this helps.
Justin
"CornDog"
1966 Dodge Charger
Re: 69 B Body Fender Mounted T-Signal Location [Re: CornDogsCharger] #914573
01/28/11 12:45 PM
01/28/11 12:45 PM
DTW
drmopar Offline
drmopar  Offline
DTW
For some reason some early 69 road runners, and GTX's came with the small fender turn signal that you would see on a sport satellite, or coronet for 1969. Somewhere in late 1968 the road runners and GTX's got the bullets. I heard the supplier who was making them for mopar was unable to make them in time.
RM27H9G 4 speed F8/tan guts
RS27L9G auto B5/black guts
WM23H9G auto F5/green guts
2021 Challenger 392 Indigo/black guts
2019 Charger Daytona R/T F8 on black
2018 Ram Sport Hemi 4x4
Re: 69 B Body Fender Mounted T-Signal Location [Re: drmopar] #914574
01/28/11 01:57 PM
01/28/11 01:57 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I've never seen the small singals on a Road Runner. Always bullet style. I have seen several 69 GTXs and Sport Sats with the small ones though.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 69 B Body Fender Mounted T-Signal Location [Re: RoadRunner] #914575
01/28/11 02:21 PM
01/28/11 02:21 PM
Rockford, IL
foz Offline OP
foz  Offline OP
Rockford, IL
I really think I need a car to LOOK at to make EXACT measurements! Anyone here in ILLINOIS near Rockford have such a car??
Kelly (foz)
Re: 69 B Body Fender Mounted T-Signal Location [Re: RoadRunner] #914576
01/28/11 02:23 PM
01/28/11 02:23 PM
DTW
drmopar Offline
drmopar  Offline
DTW
My fathers car, as well as mine had the small turn signals. We decided to go to the bullets instead because they are more common and look cooler. My dads car and mine have 801 SPD's. They are 5 VINS apart. They will both be out and about this spring next to each other for the first time since 1968. BTW they are identical twins, option for option.
Re: 69 B Body Fender Mounted T-Signal Location [Re: drmopar] #914577
01/28/11 02:23 PM
01/28/11 02:23 PM
DTW
drmopar Offline
drmopar  Offline
DTW
My tag....Previous was my dads
Re: 69 B Body Fender Mounted T-Signal Location [Re: drmopar] #914578
01/28/11 02:30 PM
01/28/11 02:30 PM
DTW
drmopar Offline
drmopar  Offline
DTW
His car just went a full nut and bolt rotisserie resto over the last 3 years. It turned out gorgeous. Mopar and collector cars did the resto, and Mr. Six pack Bob Karakashian built the 383. This is what it looked like a couple days before she came home.
Re: 69 B Body Fender Mounted T-Signal Location [Re: drmopar] #914579
01/28/11 02:31 PM
01/28/11 02:31 PM
DTW
drmopar Offline
drmopar  Offline
DTW
One more. Sorry for the thread hijack. My road runner is in the background.
Re: 69 B Body Fender Mounted T-Signal Location [Re: drmopar] #914580
01/28/11 02:34 PM
01/28/11 02:34 PM
Rockford, IL
foz Offline OP
foz  Offline OP
Rockford, IL
And they were 5 VIN's apart too???!!!!
COUNT your blessings you have a great relationship with your Dad! I think that's awesome!
Re: 69 B Body Fender Mounted T-Signal Location [Re: foz] #914581
01/28/11 03:26 PM
01/28/11 03:26 PM
DTW
drmopar Offline
drmopar  Offline
DTW
My dad is the reason Iam a car guy/mopar nut. He had a 69 RR when I was a baby, had a 69 convert when I was a small child also. That car was restored by yours truly and was finished in time for the road runner reunion at the NATS in 2005. Iam best friends with the current owner of my dads car. That road runner graced mopar action on August 2005. This is my dad and I in front of the car at the 05 Nats
